Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [StarPU] Data prefetch.
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Stojce Nakov <stojce.nakov@inria.fr>
  • Cc: Emmanuel Agullo <emmanuel.agullo@inria.fr>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [StarPU] Data prefetch.
  • Date: Wed, 29 Feb 2012 22:20:09 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
The CUDA module on plafrim was not setting the include path for the
C++ compiler. This has been fixed thanks to Cédric. However, the
compilation of CUDA applications is now broken unless you set
the environment variables NVCCFLAGS to "--compiler-options
-fpermissive" before configuring StarPU.
You would have to execute something like
% NVCCFLAGS="--compiler-options -fpermissive" configure --prefix=... ...
I am going to check if there is a way to fix this problem with a better
solution.
Cheers,
Nathalie
On Feb 29, 15:59, Nathalie Furmento wrote:
> Stojce,
> The g++ problem has been identified, and can easily be reproduced.
> We are currently working on it.
> Thanks for reporting it,
> Cheers,
> Nathalie
> On 29/02/2012 14:43, Stojce Nakov wrote:
> >I'm using the machin mirgage on plafrim.
> >Stojce
> >----- Original Message -----
> >>From: "Nathalie Furmento"<nathalie.furmento@labri.fr>
> >>To: "Stojce Nakov"<stojce.nakov@inria.fr>
> >>Cc: starpu-devel@lists.gforge.inria.fr
> >>Sent: Wednesday, February 29, 2012 2:36:28 PM
> >>Stojce,
> >>Could you please tell us on which machin you tried to compile, and
> >>send
> >>us your config.log file.
> >>Thanks,
> >>Nathalie
> >>On 29/02/2012 14:30, Stojce Nakov wrote:
> >>>Hi,
> >>>I've tested with the last version from the svn and the problem is
> >>>still here.
> >>>Also i had some problem with the compilation of starPU. When the
> >>>file
> >>>examples/cpp/incrementer_cpp.cpp is compiled, he can not find CUDA.
> >>>I've seen that there is a
> >>>Warning that it needs to be fixed, but i could not even compîle
> >>>StarPU.
> >>>Stojce
> >>>>From: "Ludovic Courtès"<ludovic.courtes@inria.fr>
> >>>>To: "Cyril Roelandt"<cyril.roelandt@inria.fr>
> >>>>Cc: "stojce nakov"<stojce.nakov@inria.fr>,
> >>>>Sent: Tuesday, February 28, 2012 2:12:17 PM
> >>>>Hi,
> >>>>Cyril Roelandt<cyril.roelandt@inria.fr> skribis:
> >>>>>About a month ago, you reported an issue related to data
> >>>>>prefetching
> >>>>>in StarPU. Can you confirm your bug still appears in the latest
> >>>>>revision of StarPU ? You can get it by running :
> >>>>>$ svn checkout svn://scm.gforge.inria.fr/svn/starpu
> >>>>Alternatively, you can use a tarball from
> >>>><http://hydra.bordeaux.inria.fr/job/runtime/starpu-trunk/tarball/latest/download-by-type/file/source-dist>,
> >>>>which saves you from the need to have up-to-date maintenance tools
> >>>>(Autotools& co.)
> >>>>Thanks,
> >>>>Ludo’.
> >>>_______________________________________________
> >>>Starpu-devel mailing list
> >>>Starpu-devel@lists.gforge.inria.fr
> >>>http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento Ingénieur de recherche CNRS
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
351 cours de la Libération, Bât A29 Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE Fax: +33 (0)5 24 57 40 41
Haut de le page
