Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
  • Date: Thu, 15 Mar 2012 07:56:12 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Le 14 mars 2012 à 09:56, Xavier Lacoste a écrit :
> Le 13 mars 2012 à 18:56, Cyril Roelandt a écrit :
>> On 02/24/2012 02:55 PM, Xavier Lacoste wrote:
>>> Le 24 févr. 2012 à 14:47, Cyril Roelandt a écrit :
>>>> On 02/24/2012 11:01 AM, Xavier Lacoste wrote:
>>>>> Hello again,
>>>>> I did a smaller example creating an empty sparse matrix and doing a
>>>>> fake factorization using StarPU.
>>>>> The problem is that for the moment it doesn't reproduce the bug.
>>>>> Can you remember me the define I gave you in config.in file in STARPU
>>>>> section ?
>>>> Hello,
>>>> Here is the content of the StarPU section in config.in:
>>>> CCPASTIX := -L/opt/cluster/plafrim-dev/hwloc/1.3.1/lib $(CCPASTIX)
>>>> `pkg-config libstarpu --cflags` -DWITH_STARPU -DSTARPU_BLOCKTAB_GEMM
>>>> -DSTARPU_BLOCKTAB_SELFCOPY
>>>> EXTRALIB := $(EXTRALIB) `pkg-config libstarpu --libs --static`
>>>> Cyril Roelandt.
>>> Ok it's what I remembered... Maybe my example (11x11 matrix) is not big
>>> enough to reproduce the bug... I don't know...
>> I see. It's probably quite hard to write a very simple program that
>> reproduces this issue. Using the exact same code you sent me, do you think
>> we could use an input file representing a smaller matrix than shipsec5.rsa
>> ? The thing is, we are trying to run helgrind on your code, but the data
>> seems big enough to prevent it from completing.
>> Cyril Roelandt.
> Mis-replied to you instead of starpu-devel :
>> The code is working on an other machine so I tried to update StarPU,
>> hoping that it was fixed, sadly it's not.
>> I cleaned some of the StarPU code in PaStiX if you want I can give you a
>> newer version...
>> The problem is that I don't really know how to simply generate a valid
>> sparse matrix so I couldn't go bigger than 11x11 matrix for the example I
>> tried to write...
>> For the input file you can use matrix/small.rsa which is smaller
>> (orsirr.rua does not crash, -mm matrix/young4c.mtc neither) you can also
>> try with -lap <size> which will create a laplacian of the given size.
>> Thanks
>> XL.
> A little precision, matrix/small.rsa only works with LDLT Factorzation (in
> the main example if you have API_FACT_LLT, change it to API_FACT_LDLT) If
> you need any help tell me.
Hello,
Runned valgrind on the small.rsa test case and all I got is that :
==1055== Syscall param write(buf) points to uninitialised byte(s)
==1055== at 0xE9207FB: (within /lib64/libpthread-2.9.so)
==1055== by 0xE70C9F7: fut_endup (fut_setup.c:325)
==1055== by 0x5579673: _starpu_stop_fxt_profiling (fxt.c:122)
==1055== by 0x557CB74: starpu_shutdown (workers.c:638)
==1055== by 0x42E803: pastix_task_clean (pastix.c:3663)
==1055== by 0x436586: pastix (pastix.c:4311)
==1055== by 0x412744: main (simple.c:204)
==1055== Address 0x1921aae0 is 2,736 bytes inside a block of size 67,108,864
alloc'd
==1055== at 0x4C256AE: malloc (in
/usr/lib64/valgrind/amd64-linux/vgpreload_memcheck.so)
==1055== by 0xE70CAE0: fut_setup (fut_setup.c:125)
==1055== by 0x5579896: _starpu_start_fxt_profiling (fxt.c:85)
==1055== by 0x557D1D2: starpu_init (workers.c:432)
==1055== by 0x432B50: pastix_task_init (pastix.c:688)
==1055== by 0x4368A6: pastix (pastix.c:3985)
Haut de le page
