Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
Archives de la liste
Chronologique Discussions
  • To: Xavier Lacoste <xavier.lacoste@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [Starpu-commits] r5692 - in trunk/src: core core/dependencies datawizard drivers/cpu drivers/cuda drivers/gordon drivers/opencl
  • Date: Tue, 13 Mar 2012 18:56:54 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 02/24/2012 02:55 PM, Xavier Lacoste wrote:
Le 24 févr. 2012 à 14:47, Cyril Roelandt a écrit :
On 02/24/2012 11:01 AM, Xavier Lacoste wrote:
Hello again,
I did a smaller example creating an empty sparse matrix and doing a fake
factorization using StarPU.
The problem is that for the moment it doesn't reproduce the bug.
Can you remember me the define I gave you in config.in file in STARPU section
Hello,
Here is the content of the StarPU section in config.in:
CCPASTIX := -L/opt/cluster/plafrim-dev/hwloc/1.3.1/lib $(CCPASTIX)
`pkg-config libstarpu --cflags` -DWITH_STARPU -DSTARPU_BLOCKTAB_GEMM
-DSTARPU_BLOCKTAB_SELFCOPY
EXTRALIB := $(EXTRALIB) `pkg-config libstarpu --libs --static`
Cyril Roelandt.
Ok it's what I remembered... Maybe my example (11x11 matrix) is not big
enough to reproduce the bug... I don't know...
I see. It's probably quite hard to write a very simple program that reproduces this issue. Using the exact same code you sent me, do you think we could use an input file representing a smaller matrix than shipsec5.rsa ? The thing is, we are trying to run helgrind on your code, but the data seems big enough to prevent it from completing.
Cyril Roelandt.
Haut de le page
