Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: uma boregowda <umaboregowda@gmail.com>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] OpenMP
- Date: Mon, 26 Mar 2012 16:32:26 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
You can certainly use the examples provided with StarPU to test your
new scheduler. It is however very difficult to tell you which
specific benchmark to use unless you tell us more about your
scheduler. Concerning the possible benefits of tasks against thread, i would advise you to read any advanced course on parallel programming. Cheers, Nathalie On 26/03/2012 02:37, uma boregowda wrote: Hi, Sir, you have very clearly said that starpu can be used by researchers to plug in their schedulers, to experiment. Thanks for making scheduler as a plug-in into starpu. Now, i wish to try new scheduling methods. Which benchmarks to use ? Should i use the ones given in examples folder. Are there are few more benchmarks to try ? I have read about task scheduling. According to you, which applications would be greatly benefited using tasks, instead of threads only. Please mention few such applications. last query - how are threads scheduled by starpu ? with best wishes uma On Sat, Mar 24, 2012 at 10:21 PM, Samuel
Thibault <samuel.thibault@ens-lyon.org>
wrote:
Nathalie Furmento, le Sat 24 Mar 2012 09:39:23 +0100, a écrit : > well, i did not understand openmp program. > > Within a task, few threads are created. > > now, where will these threads be scheduled ? > > What does the above function accomplishing ? See paragraph 5.9 "Parallel Tasks" of the StarPU handbook. Samuel |
- Re: [Starpu-devel] OpenMP, (suite)
- Re: [Starpu-devel] OpenMP, Samuel Thibault, 24/03/2012
- Re: [Starpu-devel] OpenMP, uma boregowda, 25/03/2012
- Re: [Starpu-devel] OpenMP, Samuel Thibault, 28/03/2012
- Re: [Starpu-devel] OpenMP, uma boregowda, 29/03/2012
- Re: [Starpu-devel] OpenMP, Nathalie Furmento, 29/03/2012
- Message indisponible
- Re: [Starpu-devel] OpenMP, Samuel Thibault, 29/03/2012
- Re: [Starpu-devel] OpenMP, uma boregowda, 30/03/2012
- Re: [Starpu-devel] OpenMP, Nathalie Furmento, 30/03/2012
- Re: [Starpu-devel] OpenMP, Samuel Thibault, 30/03/2012
- Re: [Starpu-devel] OpenMP, Nathalie Furmento, 26/03/2012
- Re: [Starpu-devel] OpenMP, uma boregowda, 27/03/2012
