Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Albert Sidelnik <sidelnik@gmail.com>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Constructing codelet-chain loop
- Date: Thu, 19 Apr 2012 17:42:35 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Samuel Thibault, le Thu 19 Apr 2012 17:10:08 +0200, a écrit :
> Albert Sidelnik, le Wed 18 Apr 2012 20:11:00 +0200, a écrit :
> > I'm trying emulate a "do-while" loop strictly using codelets, but my
> > program seems to be hanging,
> Using tags in a regenerable graph has not been tested, so it might
> very well be bugged. In the meanwhile, you can have a look at
> tests/main/subgraph_repeat_regenerate.c, which performs a task graph in
> a while loop, but using task dependencies instead of tags.
There is indeed a bug: starpu_tag_restart was missing. If you notify a
tag several times, only the first time will actually trigger something.
One needs to reset the tag before notifying it again. I have commited a
fix in revision 6480 to the starpu-1.0 branch, which you can fetch using
svn co svn://scm.gforge.inria.fr/svn/starpu/branches/starpu-1.0
Samuel
- [Starpu-devel] Constructing codelet-chain loop, Albert Sidelnik, 18/04/2012
- Re: [Starpu-devel] Constructing codelet-chain loop, Albert Sidelnik, 19/04/2012
- Re: [Starpu-devel] Constructing codelet-chain loop, Samuel Thibault, 19/04/2012
- <Suite(s) possible(s)>
