Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Constructing codelet-chain loop
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Albert Sidelnik <sidelnik@gmail.com>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Constructing codelet-chain loop
  • Date: Thu, 19 Apr 2012 11:47:17 -0500
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Excellent! That fixed it for me.
On Thu, Apr 19, 2012 at 10:42 AM, Samuel Thibault
<samuel.thibault@ens-lyon.org> wrote:
> Samuel Thibault, le Thu 19 Apr 2012 17:10:08 +0200, a écrit :
>> Albert Sidelnik, le Wed 18 Apr 2012 20:11:00 +0200, a écrit :
>> > I'm trying emulate a "do-while" loop strictly using codelets, but my
>> > program seems to be hanging,
>> Using tags in a regenerable graph has not been tested, so it might
>> very well be bugged.  In the meanwhile, you can have a look at
>> tests/main/subgraph_repeat_regenerate.c, which performs a task graph in
>> a while loop, but using task dependencies instead of tags.
> There is indeed a bug: starpu_tag_restart was missing.  If you notify a
> tag several times, only the first time will actually trigger something.
> One needs to reset the tag before notifying it again.  I have commited a
> fix in revision 6480 to the starpu-1.0 branch, which you can fetch using
> svn co svn://scm.gforge.inria.fr/svn/starpu/branches/starpu-1.0
> Samuel
Haut de le page
