Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: "Rafique, Abid" <a.rafique09@imperial.ac.uk>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU installation error
- Date: Tue, 24 Apr 2012 10:02:13 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Abid, Could you please tell us which version of StarPU you are using and send us the config.log file (which has been generated by the configure command). You should not need to call sudo make, make does not need to be run as root. (You will only need to use sudo when calling make install if the installation is to be done in a general directory). Cheers, Nathalie On 23/04/2012 20:56, Rafique, Abid wrote: Hi, I am trying to install StarPU on system having 1 GPU. CUDA is installed in the directory /usr/local/cuda abid@jam10:~/starpu-1.0.0$ sudo make Making all in src make[1]: Entering directory `/home/abid/starpu-1.0.0/src' make[2]: Entering directory `/home/abid/starpu-1.0.0/src' make[2]: Nothing to be done for `all-am'. make[2]: Leaving directory `/home/abid/starpu-1.0.0/src' make[1]: Leaving directory `/home/abid/starpu-1.0.0/src' Making all in tools make[1]: Entering directory `/home/abid/starpu-1.0.0/tools' make[2]: Entering directory `/home/abid/starpu-1.0.0/tools' CCLD starpu_calibrate_bus /usr/bin/ld: warning: libcudart.so.4, needed by ../src/.libs/libstarpu-1.0.so, not found (try using -rpath or -rpath-link) /usr/bin/ld: warning: libcublas.so.4, needed by ../src/.libs/libstarpu-1.0.so, not found (try using -rpath or -rpath-link) ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaMemcpyPeerAsync' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaFreeHost' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaFree' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaEventDestroy' ../src/.libs/libstarpu-1.0.so: undefined reference to `cublasShutdown' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaHostAlloc' ../src/.libs/libstarpu-1.0.so: undefined reference to `cublasGetCurrentCtx' ../src/.libs/libstarpu-1.0.so: undefined reference to `cublasSetStream_v2' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaEventSynchronize' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaMemset' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaThreadExit' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaThreadSynchronize' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaGetErrorString' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaMemcpy2D' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaStreamSynchronize' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaGetDeviceCount' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaGetDeviceProperties' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaEventQuery' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaEventCreate' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaSetDevice' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaMemcpy2DAsync' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaStreamCreate' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaStreamDestroy' ../src/.libs/libstarpu-1.0.so: undefined reference to `cublasInit' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaMemcpyPeer' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaMemcpy' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaMalloc' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaEventRecord' ../src/.libs/libstarpu-1.0.so: undefined reference to `cudaMemcpyAsync' collect2: ld returned 1 exit status make[2]: *** [starpu_calibrate_bus] Error 1 make[2]: Leaving directory `/home/abid/starpu-1.0.0/tools' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/home/abid/starpu-1.0.0/tools' make: *** [all-recursive] Error 1 Best abid _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel |
- [Starpu-devel] StarPU installation error, Rafique, Abid, 23/04/2012
- Re: [Starpu-devel] StarPU installation error, Nathalie Furmento, 24/04/2012
- Message indisponible
