Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: "Rafique, Abid" <a.rafique09@imperial.ac.uk>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU installation error
- Date: Tue, 24 Apr 2012 14:17:39 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
This is a multi-part message in MIME format. On 24/04/2012 13:32, Rafique, Abid wrote:
I have gone through the config.log it seems to me that the my cuda libraries (CUDA 4.0) are incompatible with the StarPU (starpu-1.0.0). Please find the log file attached.
Based on your config.log file, CUDA has been detected properly
STARPU_CUDA_CPPFLAGS='-I/usr/local/cuda/include'
STARPU_CUDA_FORTRAN_LDFLAGS='-lgfortran'
STARPU_CUDA_LDFLAGS=' -L/usr/local/cuda/lib64 -lcudart -lcublas -lcuda -lstdc++'
STARPU_USE_CUDA='yes'
STARPU_USE_CUDA_FALSE='#'
STARPU_USE_CUDA_TRUE=''
#define STARPU_MAXCUDADEVS 4
#define STARPU_USE_CUDA 1
Could you send us the output of the command make V=1
Also, please send your answer to the mailing list and not only to me.
Thanks,
Nathalie
This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by StarPU configure 1.0.0, which was generated by GNU Autoconf 2.68. Invocation command line was $ ./configure ## --------- ## ## Platform. ## ## --------- ## hostname = jam10.ee.ic.ac.uk uname -m = x86_64 uname -r = 2.6.32-31-generic uname -s = Linux uname -v = #61-Ubuntu SMP Fri Apr 8 18:25:51 UTC 2011 /usr/bin/uname -p = unknown /bin/uname -X = unknown /bin/arch = unknown /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown /usr/bin/hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown
- [Starpu-devel] StarPU installation error, Rafique, Abid, 23/04/2012
- Re: [Starpu-devel] StarPU installation error, Nathalie Furmento, 24/04/2012
- Message indisponible
