Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Make the FxT-related code portable.
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Make the FxT-related code portable.
  • Date: Tue, 24 Apr 2012 14:27:50 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
On what systems have we tested StarPU with FxT ? Ludovic recently added a "with_fxt" profile on hydra, and it seems to only work on Linux and Darwin. It fails on FreeBSD and GNU, and I have no idea what it does on Windows.
The attached patch should fix the build on FreeBSD. I haven't tested the MPI part, but it should be fine. I can see very nice generated traces on both FreeBSD and Linux. The thing is, I'm not sure it __really__ works on Darwin: it is weird that they have a gettid syscall (cf. http://elliotth.blogspot.fr/2012/04/gettid-on-mac-os.html).
Do we have a Darwin machine to test this ? And how about a Windows machine ?
Cyril.
diff --git a/trunk/mpi/starpu_mpi_fxt.h b/trunk/mpi/starpu_mpi_fxt.h
index fc2ff48..c3b60ef 100644
--- a/trunk/mpi/starpu_mpi_fxt.h
+++ b/trunk/mpi/starpu_mpi_fxt.h
@@ -28,11 +28,11 @@
 #ifdef STARPU_USE_FXT
 #define TRACE_MPI_BARRIER(rank, worldsize, key)	\
-	FUT_DO_PROBE4(FUT_MPI_BARRIER, (rank), (worldsize), (key), syscall(SYS_gettid));
+	FUT_DO_PROBE4(FUT_MPI_BARRIER, (rank), (worldsize), (key), _starpu_gettid());
 #define TRACE_MPI_ISEND(dest, mpi_tag, size)	\
-	FUT_DO_PROBE4(FUT_MPI_ISEND, (dest), (mpi_tag), (size), syscall(SYS_gettid));
+	FUT_DO_PROBE4(FUT_MPI_ISEND, (dest), (mpi_tag), (size), _starpu_gettid());
 #define TRACE_MPI_IRECV_END(src, mpi_tag)	\
-	FUT_DO_PROBE3(FUT_MPI_IRECV_END, (src), (mpi_tag), syscall(SYS_gettid));
+	FUT_DO_PROBE3(FUT_MPI_IRECV_END, (src), (mpi_tag), _starpu_gettid());
 #define TRACE
 #else
 #define TRACE_MPI_BARRIER(a, b, c)	do {} while(0);
diff --git a/trunk/src/common/fxt.c b/trunk/src/common/fxt.c
index 3fb61c9..6b61f9c 100644
--- a/trunk/src/common/fxt.c
+++ b/trunk/src/common/fxt.c
@@ -38,6 +38,24 @@ static int _starpu_written = 0;
 static int _starpu_id;
+#if defined(__linux__) || defined(__APPLE__)
+#include <sys/syscall.h>
+#elif defined(__FreeBSD__)
+#include <sys/thr.h>
+#endif
+long _starpu_gettid()
+#if defined(__linux__) || defined (__APPLE__)
+	return syscall(SYS_gettid);
+	long ltid;
+	thr_self(&ltid);
+	return ltid;
+#else
+#error "Unknown operating system."
+#endif
 static void _starpu_profile_set_tracefile(void *last, ...)
 	va_list vl;
@@ -78,7 +96,7 @@ void _starpu_start_fxt_profiling(void)
 		_starpu_profile_set_tracefile(NULL);
-	threadid = syscall(SYS_gettid);
+	threadid = _starpu_gettid();
 	atexit(_starpu_stop_fxt_profiling);
@@ -140,7 +158,7 @@ void _starpu_stop_fxt_profiling(void)
 void _starpu_fxt_register_thread(unsigned cpuid)
-	FUT_DO_PROBE2(FUT_NEW_LWP_CODE, cpuid, syscall(SYS_gettid));
+	FUT_DO_PROBE2(FUT_NEW_LWP_CODE, cpuid, _starpu_gettid());
 #endif // STARPU_USE_FXT
diff --git a/trunk/src/common/fxt.h b/trunk/src/common/fxt.h
index b836186..8f84861 100644
--- a/trunk/src/common/fxt.h
+++ b/trunk/src/common/fxt.h
@@ -103,10 +103,11 @@
 #define _STARPU_FUT_TASK_WAIT_FOR_ALL	0x513b
-#include <sys/syscall.h> /* pour les définitions de SYS_xxx */
 #include <fxt/fxt.h>
 #include <fxt/fut.h>
+long _starpu_gettid(void);
 /* Initialize the FxT library. */
 void _starpu_start_fxt_profiling(void);
@@ -178,13 +179,13 @@ do {									\
 /* workerkind = _STARPU_FUT_CPU_KEY for instance */
 #define _STARPU_TRACE_NEW_MEM_NODE(nodeid)			\
-	FUT_DO_PROBE2(_STARPU_FUT_NEW_MEM_NODE, nodeid, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_NEW_MEM_NODE, nodeid, _starpu_gettid());
 #define _STARPU_TRACE_WORKER_INIT_START(workerkind, devid, memnode)	\
-	FUT_DO_PROBE4(_STARPU_FUT_WORKER_INIT_START, workerkind, devid, memnode, syscall(SYS_gettid));
+	FUT_DO_PROBE4(_STARPU_FUT_WORKER_INIT_START, workerkind, devid, memnode, _starpu_gettid());
 #define _STARPU_TRACE_WORKER_INIT_END				\
-	FUT_DO_PROBE1(_STARPU_FUT_WORKER_INIT_END, syscall(SYS_gettid));
+	FUT_DO_PROBE1(_STARPU_FUT_WORKER_INIT_END, _starpu_gettid());
 #define _STARPU_TRACE_START_CODELET_BODY(job)				\
 do {									\
@@ -192,10 +193,10 @@ do {									\
 	if (model_name)                                                 \
 		/* we include the symbol name */			\
-		_STARPU_FUT_DO_PROBE3STR(_STARPU_FUT_START_CODELET_BODY, (job), syscall(SYS_gettid), 1, model_name); \
+		_STARPU_FUT_DO_PROBE3STR(_STARPU_FUT_START_CODELET_BODY, (job), _starpu_gettid(), 1, model_name); \
 	else {                                                          \
-		FUT_DO_PROBE3(_STARPU_FUT_START_CODELET_BODY, (job), syscall(SYS_gettid), 0); \
+		FUT_DO_PROBE3(_STARPU_FUT_START_CODELET_BODY, (job), _starpu_gettid(), 0); \
 } while(0);
@@ -203,35 +204,35 @@ do {									\
 do {									\
 	const size_t job_size = _starpu_job_get_data_size((job)->task->cl?(job)->task->cl->model:NULL, archtype, nimpl, (job));	\
 	const uint32_t job_hash = _starpu_compute_buffers_footprint((job)->task->cl?(job)->task->cl->model:NULL, archtype, nimpl, (job));\
-	FUT_DO_PROBE5(_STARPU_FUT_END_CODELET_BODY, (job), (job_size), (job_hash), (archtype), syscall(SYS_gettid));	\
+	FUT_DO_PROBE5(_STARPU_FUT_END_CODELET_BODY, (job), (job_size), (job_hash), (archtype), _starpu_gettid());	\
 } while(0);
 #define _STARPU_TRACE_START_CALLBACK(job)	\
-	FUT_DO_PROBE2(_STARPU_FUT_START_CALLBACK, job, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_START_CALLBACK, job, _starpu_gettid());
 #define _STARPU_TRACE_END_CALLBACK(job)	\
-	FUT_DO_PROBE2(_STARPU_FUT_END_CALLBACK, job, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_END_CALLBACK, job, _starpu_gettid());
 #define _STARPU_TRACE_JOB_PUSH(task, prio)	\
-	FUT_DO_PROBE3(_STARPU_FUT_JOB_PUSH, task, prio, syscall(SYS_gettid));
+	FUT_DO_PROBE3(_STARPU_FUT_JOB_PUSH, task, prio, _starpu_gettid());
 #define _STARPU_TRACE_JOB_POP(task, prio)	\
-	FUT_DO_PROBE3(_STARPU_FUT_JOB_POP, task, prio, syscall(SYS_gettid));
+	FUT_DO_PROBE3(_STARPU_FUT_JOB_POP, task, prio, _starpu_gettid());
 #define _STARPU_TRACE_UPDATE_TASK_CNT(counter)	\
-	FUT_DO_PROBE2(_STARPU_FUT_UPDATE_TASK_CNT, counter, syscall(SYS_gettid))
+	FUT_DO_PROBE2(_STARPU_FUT_UPDATE_TASK_CNT, counter, _starpu_gettid())
 #define _STARPU_TRACE_START_FETCH_INPUT(job)	\
-	FUT_DO_PROBE2(_STARPU_FUT_START_FETCH_INPUT, job, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_START_FETCH_INPUT, job, _starpu_gettid());
 #define _STARPU_TRACE_END_FETCH_INPUT(job)	\
-	FUT_DO_PROBE2(_STARPU_FUT_END_FETCH_INPUT, job, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_END_FETCH_INPUT, job, _starpu_gettid());
 #define _STARPU_TRACE_START_PUSH_OUTPUT(job)	\
-	FUT_DO_PROBE2(_STARPU_FUT_START_PUSH_OUTPUT, job, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_START_PUSH_OUTPUT, job, _starpu_gettid());
 #define _STARPU_TRACE_END_PUSH_OUTPUT(job)	\
-	FUT_DO_PROBE2(_STARPU_FUT_END_PUSH_OUTPUT, job, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_END_PUSH_OUTPUT, job, _starpu_gettid());
 #define _STARPU_TRACE_TAG(tag, job)	\
 	FUT_DO_PROBE2(_STARPU_FUT_TAG, tag, (job)->job_id)
@@ -251,10 +252,10 @@ do {										\
         const char *model_name = _starpu_get_model_name((job));                       \
 	if (model_name)					                        \
-		_STARPU_FUT_DO_PROBE4STR(_STARPU_FUT_TASK_DONE, (job)->job_id, syscall(SYS_gettid), (long unsigned)exclude_from_dag, 1, model_name);\
+		_STARPU_FUT_DO_PROBE4STR(_STARPU_FUT_TASK_DONE, (job)->job_id, _starpu_gettid(), (long unsigned)exclude_from_dag, 1, model_name);\
 	else {									\
-		FUT_DO_PROBE4(_STARPU_FUT_TASK_DONE, (job)->job_id, syscall(SYS_gettid), (long unsigned)exclude_from_dag, 0);\
+		FUT_DO_PROBE4(_STARPU_FUT_TASK_DONE, (job)->job_id, _starpu_gettid(), (long unsigned)exclude_from_dag, 0);\
 } while(0);
@@ -264,10 +265,10 @@ do {										\
 	if (model_name)                                                         \
-          _STARPU_FUT_DO_PROBE3STR(_STARPU_FUT_TAG_DONE, (tag)->id, syscall(SYS_gettid), 1, model_name); \
+          _STARPU_FUT_DO_PROBE3STR(_STARPU_FUT_TAG_DONE, (tag)->id, _starpu_gettid(), 1, model_name); \
 	else {									\
-		FUT_DO_PROBE3(_STARPU_FUT_TAG_DONE, (tag)->id, syscall(SYS_gettid), 0);\
+		FUT_DO_PROBE3(_STARPU_FUT_TAG_DONE, (tag)->id, _starpu_gettid(), 0);\
 } while(0);
@@ -290,56 +291,56 @@ do {										\
 	FUT_DO_PROBE2(_STARPU_FUT_WORK_STEALING, empty_q, victim_q)
 #define _STARPU_TRACE_WORKER_DEINIT_START			\
-	FUT_DO_PROBE1(_STARPU_FUT_WORKER_DEINIT_START, syscall(SYS_gettid));
+	FUT_DO_PROBE1(_STARPU_FUT_WORKER_DEINIT_START, _starpu_gettid());
 #define _STARPU_TRACE_WORKER_DEINIT_END(workerkind)		\
-	FUT_DO_PROBE2(_STARPU_FUT_WORKER_DEINIT_END, workerkind, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_WORKER_DEINIT_END, workerkind, _starpu_gettid());
 #define _STARPU_TRACE_WORKER_SLEEP_START	\
-	FUT_DO_PROBE1(_STARPU_FUT_WORKER_SLEEP_START, syscall(SYS_gettid));
+	FUT_DO_PROBE1(_STARPU_FUT_WORKER_SLEEP_START, _starpu_gettid());
 #define _STARPU_TRACE_WORKER_SLEEP_END	\
-	FUT_DO_PROBE1(_STARPU_FUT_WORKER_SLEEP_END, syscall(SYS_gettid));
+	FUT_DO_PROBE1(_STARPU_FUT_WORKER_SLEEP_END, _starpu_gettid());
 #define _STARPU_TRACE_USER_DEFINED_START	\
-	FUT_DO_PROBE1(_STARPU_FUT_USER_DEFINED_START, syscall(SYS_gettid));
+	FUT_DO_PROBE1(_STARPU_FUT_USER_DEFINED_START, _starpu_gettid());
 #define _STARPU_TRACE_USER_DEFINED_END		\
-	FUT_DO_PROBE1(_STARPU_FUT_USER_DEFINED_END, syscall(SYS_gettid));
+	FUT_DO_PROBE1(_STARPU_FUT_USER_DEFINED_END, _starpu_gettid());
 #define _STARPU_TRACE_START_ALLOC(memnode)		\
-	FUT_DO_PROBE2(_STARPU_FUT_START_ALLOC, memnode, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_START_ALLOC, memnode, _starpu_gettid());
 #define _STARPU_TRACE_END_ALLOC(memnode)		\
-	FUT_DO_PROBE2(_STARPU_FUT_END_ALLOC, memnode, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_END_ALLOC, memnode, _starpu_gettid());
 #define _STARPU_TRACE_START_ALLOC_REUSE(memnode)		\
-	FUT_DO_PROBE2(_STARPU_FUT_START_ALLOC_REUSE, memnode, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_START_ALLOC_REUSE, memnode, _starpu_gettid());
 #define _STARPU_TRACE_END_ALLOC_REUSE(memnode)		\
-	FUT_DO_PROBE2(_STARPU_FUT_END_ALLOC_REUSE, memnode, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_END_ALLOC_REUSE, memnode, _starpu_gettid());
 #define _STARPU_TRACE_START_MEMRECLAIM(memnode)		\
-	FUT_DO_PROBE2(_STARPU_FUT_START_MEMRECLAIM, memnode, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_START_MEMRECLAIM, memnode, _starpu_gettid());
 #define _STARPU_TRACE_END_MEMRECLAIM(memnode)		\
-	FUT_DO_PROBE2(_STARPU_FUT_END_MEMRECLAIM, memnode, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_END_MEMRECLAIM, memnode, _starpu_gettid());
 /* We skip these events becasue they are called so often that they cause FxT to
  * fail and make the overall trace unreadable anyway. */
 #define _STARPU_TRACE_START_PROGRESS(memnode)		\
 	do {} while (0);
-//	FUT_DO_PROBE2(_STARPU_FUT_START_PROGRESS, memnode, syscall(SYS_gettid));
+//	FUT_DO_PROBE2(_STARPU_FUT_START_PROGRESS, memnode, _starpu_gettid());
 #define _STARPU_TRACE_END_PROGRESS(memnode)		\
 	do {} while (0);
-	//FUT_DO_PROBE2(_STARPU_FUT_END_PROGRESS, memnode, syscall(SYS_gettid));
+	//FUT_DO_PROBE2(_STARPU_FUT_END_PROGRESS, memnode, _starpu_gettid());
 #define _STARPU_TRACE_USER_EVENT(code)			\
-	FUT_DO_PROBE2(_STARPU_FUT_USER_EVENT, code, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_USER_EVENT, code, _starpu_gettid());
 #define _STARPU_TRACE_SET_PROFILING(status)		\
-	FUT_DO_PROBE2(_STARPU_FUT_SET_PROFILING, status, syscall(SYS_gettid));
+	FUT_DO_PROBE2(_STARPU_FUT_SET_PROFILING, status, _starpu_gettid());
 #define _STARPU_TRACE_TASK_WAIT_FOR_ALL			\
 	FUT_DO_PROBE0(_STARPU_FUT_TASK_WAIT_FOR_ALL)
Haut de le page
