Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Requested Output
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Requested Output
  • Date: Tue, 24 Apr 2012 13:59:53 +0000
  • Accept-language: en-GB, en-US
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi Samuel,
I met you at ASEArch Workshop at Oxford and discussed about incorporating
FPGA into StarPU.
Here is the output of of the requested file.
# libstarpu-1.0.la - a libtool library file
# Generated by libtool (GNU libtool) 2.4.2 Debian-2.4.2-1
# Please DO NOT delete this file!
# It is necessary for linking the library.
# The name that we can dlopen(3).
dlname='libstarpu-1.0.so.1'
# Names of this library.
library_names='libstarpu-1.0.so.1.0.0 libstarpu-1.0.so.1 libstarpu-1.0.so'
# The name of the static archive.
old_library='libstarpu-1.0.a'
# Linker flags that can not go in dependency_libs.
inherited_linker_flags=''
# Libraries that this one depends upon.
dependency_libs=' -L/usr/local/cuda/lib64 -lcudart -lcublas -lcuda -lstdc++
-L/usr/local/cuda/lib -lOpenCL -lrt -lm -lpthread'
# Names of additional weak libraries provided by this library
weak_library_names=''
# Version information for libstarpu-1.0.
current=1
age=0
revision=0
# Is this an already installed library?
installed=no
# Should we warn about portability when linking against -modules?
shouldnotlink=no
# Files to dlopen/dlpreopen
dlopen=''
dlpreopen=''
# Directory that this library needs to be installed in:
libdir='/usr/local/lib'
________________________________________
From: Samuel Thibault [samuel.thibault@ens-lyon.org]
Sent: 24 April 2012 13:54
To: Rafique, Abid; starpu-devel@lists.gforge.inria.fr
Samuel Thibault, le Tue 24 Apr 2012 14:54:05 +0200, a écrit :
> Rafique, Abid, le Tue 24 Apr 2012 14:43:31 +0200, a écrit :
> > /bin/sh ../libtool --tag=CC --mode=link gcc -I/usr/local/cuda/include
> > -I/
> > -DSTARPU_OPENCL_DATADIR=/usr/local/share/starpu/opencl
> > -g -O2 -O3 -gdwarf-2 -g3 -o starpu_calibrate_bus
> > starpu_calibrate_bus.o ../
> > src/libstarpu-1.0.la -lrt -lm -lpthread
> > libtool: link: gcc -I/usr/local/cuda/include -I/usr/local/cuda/include
> > -DSTARPU_OPENCL_DATADIR=/usr/local/share/starpu/opencl -g -O2 -O3
> > -gdwarf-2 -g3
> > -o .libs/starpu_calibrate_bus starpu_calibrate_bus.o ../src/.libs/
> > libstarpu-1.0.so -lrt -lm -lpthread
> > /usr/bin/ld: warning: libcudart.so.4, needed by
> > ../src/.libs/libstarpu-1.0.so,
> > not found (try using -rpath or -rpath-link)
> libtool should be able to add the path to CUDA itself, but for some
> reason it didn't. Could you post the output of src/libstarpu-1.0.la?
I meant "post the content of src/libstarpu-1.0.la".
Haut de le page
