Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Requested Output
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: "Rafique, Abid" <a.rafique09@imperial.ac.uk>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Requested Output
  • Date: Tue, 24 Apr 2012 18:29:35 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Rafique, Abid, le Tue 24 Apr 2012 14:43:31 +0200, a écrit :
> libtool: link: gcc -I/usr/local/cuda/include -I/usr/local/cuda/include
> -DSTARPU_OPENCL_DATADIR=/usr/local/share/starpu/opencl -g -O2 -O3 -gdwarf-2
> -g3
> -o .libs/starpu_calibrate_bus starpu_calibrate_bus.o ../src/.libs/
> libstarpu-1.0.so -lrt -lm -lpthread
> /usr/bin/ld: warning: libcudart.so.4, needed by
> ../src/.libs/libstarpu-1.0.so,
> not found (try using -rpath or -rpath-link)
I've experimented a bit with it. What you are missing is putting CUDA in
the execution path:
export LD_LIBRARY_PATH=/usr/local/lib64
That will be needed to execute the compiled result, anyway.
Samuel
Haut de le page
