Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Keisuke Fukuda <fukuda@matsulab.is.titech.ac.jp>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Combined workers and OpenMP code
- Date: Wed, 25 Apr 2012 17:42:57 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Keisuke Fukuda, le Wed 25 Apr 2012 11:36:44 +0200, a écrit :
> starpu_combined_worker_get_size() always returns 1
I notice that your program uses a regression-based performance model,
but it only submits tasks of the same size. The scheduler does not
realize that it's still a task of the same size, which will not help the
performance model, and thus continues to try with 1, in the hope the
performance model will eventually provide estimations.
> and only 1 thread runs in #pragma omp parallel for loop.
> OTOH, vector_scal example run 2-4 threads (although I expect 6 workers since
> the CPU is 6-core sandy bridge).
Doesn't starpu_perfmodel_display show that it at least tried 6 a few
times, perhaps only to realize that it's less efficient than 2-4?
> (2) Is there any way to let (or even force) StarPU to use a certain
> number of workers, i.e.
> just as the same number as of physical cores.
You can use the execute_on_a_specific_worker field to force using a
combined worker. Nicolas, is there any way to print the combined
workers tree? Also, it seems that STARPU_MIN/MAX_WORKERSIZE are not
documented at all, could you handle that?
Samuel
- [Starpu-devel] Combined workers and OpenMP code, Keisuke Fukuda, 25/04/2012
- <Suite(s) possible(s)>
- Re: [Starpu-devel] Combined workers and OpenMP code, Samuel Thibault, 25/04/2012
- Re: [Starpu-devel] Combined workers and OpenMP code, Keisuke Fukuda, 26/04/2012
- Re: [Starpu-devel] Combined workers and OpenMP code, Samuel Thibault, 26/04/2012
- Re: [Starpu-devel] Combined workers and OpenMP code, Nicolas Collin, 26/04/2012
- Re: [Starpu-devel] Combined workers and OpenMP code, Keisuke Fukuda, 27/04/2012
