Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Combined workers and OpenMP code
Archives de la liste
Chronologique Discussions
  • From: Keisuke Fukuda <fukuda@matsulab.is.titech.ac.jp>
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Keisuke Fukuda <fukuda@matsulab.is.titech.ac.jp>, starpu-devel@lists.gforge.inria.fr, nicolas.collin@inria.fr
  • Subject: Re: [Starpu-devel] Combined workers and OpenMP code
  • Date: Thu, 26 Apr 2012 20:09:21 +0900
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Thank you for your reply, Samuel.
> I notice that your program uses a regression-based performance model,
> but it only submits tasks of the same size.  The scheduler does not
> realize that it's still a task of the same size, which will not help the
> performance model, and thus continues to try with 1, in the hope the
> performance model will eventually provide estimations.
I changed my code to use various array size and it started to use
multiple cores. Great.
https://gist.github.com/2488259
But mine and vector_scal still use only upto 4 cores. I investigated a
little and found that
StarPU only recognized 4 cores.
Here's a result from starpu_machine_display :
$ starpu_machine_display
StarPU has found :
4 CPU cores
CPU 0
CPU 1
CPU 2
CPU 3
2 CUDA devices
CUDA 0 (Tesla C2050 2.6 GiB 01:00.0)
CUDA 1 (Tesla C2050 2.6 GiB 02:00.0)
0 OpenCL devices
(snip)
I checked "lstopo" command and made sure that hwloc recognizes 6 cores.
Why StarPU doesn't recognize the other 2 cores?
Is it a compile-time prblem or environmental configuration problem?
> You can use the execute_on_a_specific_worker field to force using a
> combined worker.  Nicolas, is there any way to print the combined
> workers tree?  Also, it seems that STARPU_MIN/MAX_WORKERSIZE are not
> documented at all, could you handle that?
I've not yet tried these but they must be useful !
Regards.
Keisuke
FUKUDA, Keisuke<fukuda@matsulab.is.titech.ac.jp>
Dept. of Math. & Comp. Sciences
Satoshi Matsuoka Lab.,
Tokyo Institute of Technology
Haut de le page
