Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] Error while make checking StarPU 1.0.1
- Date: Sat, 2 Jun 2012 10:08:16 +0600 (YEKT)
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello!
I was compiling StarPU from source code (oh, when RPMs will be available...):
./configure --enable-memory-status --enable-stats
CPUs enabled: yes
CUDA enabled: yes
OpenCL enabled: yes
Cell enabled: no
Compile-time limits
(change these with --enable-maxcpus, --enable-maxcudadev,
--enable-maxopencldev, --enable-maxbuffers)
Maximum number of CPUs: 64
Maximum number of CUDA devices: 4
Maximum number of OpenCL devices: 8
Maximum number of memory nodes: 13
Maximum number of task buffers: 8
GPU-GPU transfers: yes
Allocation cache: no
Magma enabled: no
BLAS library: none
hwloc: yes
FxT trace enabled: no
StarPU-Top: no
StarPU Extensions:
MPI enabled: no
MPI test suite: no
FFT Support: yes
GCC plug-in: no
GCC plug-in test suite (requires GNU Guile): no
SOCL enabled: yes
make was done without any errors but with warning:
*** Warning: Linking the shared library libstarpufft-1.0.la against the
non-libtool
*** objects cudaf_kernels.o cuda_kernels.o is not portable!
make check returns this:
PASS: starpu_machine_display
PASS: main/deprecated_func
PASS: main/deprecated_buffer
PASS: main/restart
PASS: main/execute_on_a_specific_worker
PASS: main/insert_task
PASS: main/multithreaded
PASS: main/multithreaded_init
PASS: main/starpu_task_bundle
PASS: main/starpu_task_wait_for_all
PASS: main/static_restartable
PASS: main/static_restartable_using_initializer
PASS: main/static_restartable_tag
PASS: main/regenerate
PASS: main/wait_all_regenerable_tasks
PASS: main/subgraph_repeat
PASS: main/subgraph_repeat_regenerate
PASS: main/subgraph_repeat_regenerate_tag
PASS: main/empty_task
PASS: main/empty_task_sync_point
PASS: main/empty_task_sync_point_tasks
PASS: main/empty_task_chain
PASS: main/tag_wait_api
PASS: main/task_wait_api
PASS: main/declare_deps_in_callback
PASS: main/declare_deps_after_submission
PASS: main/declare_deps_after_submission_synchronous
PASS: main/get_current_task
PASS: main/starpu_init
PASS: main/starpu_worker_exists
PASS: datawizard/acquire_cb
PASS: datawizard/acquire_cb_insert
PASS: datawizard/acquire_release
PASS: datawizard/acquire_release2
PASS: datawizard/copy
PASS: datawizard/data_implicit_deps
PASS: datawizard/data_lookup
PASS: datawizard/scratch
PASS: datawizard/sync_and_notify_data
PASS: datawizard/sync_and_notify_data_implicit
PASS: datawizard/dsm_stress
PASS: datawizard/double_parameter
PASS: datawizard/write_only_tmp_buffer
PASS: datawizard/data_invalidation
PASS: datawizard/dining_philosophers
PASS: datawizard/manual_reduction
PASS: datawizard/readers_and_writers
PASS: datawizard/unpartition
PASS: datawizard/user_interaction_implicit <=== there was a long time
waiting after this line
FAIL: datawizard/reclaim
PASS: datawizard/sync_with_data_with_mem
PASS: datawizard/sync_with_data_with_mem_non_blocking
PASS: datawizard/sync_with_data_with_mem_non_blocking_implicit
PASS: datawizard/mpi_like
PASS: datawizard/mpi_like_async
PASS: datawizard/critical_section_with_void_interface
PASS: datawizard/increment_redux
PASS: datawizard/increment_redux_v2
PASS: datawizard/increment_redux_lazy
PASS: datawizard/handle_to_pointer
PASS: datawizard/lazy_allocation
PASS: datawizard/interfaces/copy_interfaces
PASS: datawizard/interfaces/block/block_interface
PASS: datawizard/interfaces/bcsr/bcsr_interface
PASS: datawizard/interfaces/csr/csr_interface
PASS: datawizard/interfaces/matrix/matrix_interface
PASS: datawizard/interfaces/multiformat/multiformat_interface
SKIP: datawizard/interfaces/multiformat/advanced/multiformat_cuda_opencl
SKIP: datawizard/interfaces/multiformat/advanced/multiformat_data_release
PASS: datawizard/interfaces/multiformat/advanced/multiformat_worker
PASS: datawizard/interfaces/multiformat/advanced/multiformat_handle_conversion
PASS: datawizard/interfaces/multiformat/advanced/same_handle
PASS: datawizard/interfaces/variable/variable_interface
PASS: datawizard/interfaces/vector/test_vector_interface
PASS: datawizard/interfaces/void/void_interface
PASS: datawizard/in_place_partition
PASS: datawizard/partition_lazy
PASS: datawizard/gpu_register
PASS: datawizard/wt_host
PASS: datawizard/wt_broadcast
SKIP: datawizard/readonly
PASS: errorcheck/starpu_init_noworker
PASS: errorcheck/invalid_blocking_calls
PASS: errorcheck/invalid_tasks
PASS: helper/cublas_init
PASS: helper/starpu_data_cpy
PASS: helper/pinned_memory
PASS: helper/execute_on_all
PASS: helper/starpu_create_sync_task
PASS: microbenchs/async_tasks_overhead
PASS: microbenchs/sync_tasks_overhead
PASS: microbenchs/tasks_overhead
PASS: microbenchs/prefetch_data_on_node
PASS: microbenchs/redundant_buffer
PASS: microbenchs/local_pingpong
PASS: overlap/overlap
PASS: parallel_tasks/explicit_combined_worker
PASS: parallel_tasks/parallel_kernels
PASS: parallel_tasks/parallel_kernels_spmd
PASS: perfmodels/regression_based
PASS: perfmodels/non_linear_regression_based
Test "datawizard/reclaim" was failed:
1 of 99 tests failed
(3 tests were not run)
See tests/test-suite.log
Please report to starpu-devel@lists.gforge.inria.fr
test-suite.log is in attachment
Please tell me what I've doing wrong
Thanks
With best regards
Konstantin M. Khankin
SUSU, Computer Department, P.G.
StarPU 1.0.1: tests/test-suite.log
1 of 99 tests failed. (3 tests were not run).
.. contents:: :depth: 2
FAIL: datawizard/reclaim (exit: 1)
Allocate 15 buffers and create 1000 tasks
Warning: StarPU was configured with --enable-memory-status, which slows down
a bit
Warning: StarPU was configured with --enable-stats, which slows down a bit
[error] test has been blocked for 600 seconds. Mark it as failed
(exit: 77)
a bit
MSI cache stats :
TOTAL MSI stats hit 1 (25.00 %) miss 3 (75.00 %)
memory node 0
hit : 0 (0.00 %)
miss : 1 (100.00 %)
memory node 1
hit : 1 (33.33 %)
miss : 2 (66.67 %)
Allocation cache stats:
memory node 1
total alloc : 1
cached alloc: 0 (0.00 %)
Data transfers stats:
TOTAL transfers 0.000244 MB
1 <-> 0 0.000122 MB
1 -> 0 0.000061 MB
0 -> 1 0.000061 MB
(exit: 77)
a bit
SKIP: datawizard/readonly (exit: 77)
a bit
copy 0
submission of task 0xfaf2f0 wih codelet 0x601320 failed (symbol `none')
MSI cache stats :
TOTAL MSI stats hit 1 (100.00 %) miss 0 (0.00 %)
memory node 0
hit : 1 (100.00 %)
miss : 0 (0.00 %)
TOTAL transfers 0.000000 MB
WARNING: No one can execute this task
- [Starpu-devel] Error while make checking StarPU 1.0.1, Konstantin M. Khankin, 02/06/2012
- Re: [Starpu-devel] Error while make checking StarPU 1.0.1, Nathalie Furmento, 04/06/2012
