Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Error while make checking StarPU 1.0.1
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: "Konstantin M. Khankin" <hc@comp.susu.ac.ru>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Error while make checking StarPU 1.0.1
  • Date: Mon, 04 Jun 2012 13:08:19 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Konstantin,
The test datawizard/reclaim stresses the memory allocation system to force StarPU to reclaim memory from time to time. As it tries to allocate 50% of the available memory on your computer, it may fail depending on what other applications are running. In your case, the test has been blocked for 600 seconds, and therefore mark as failed.
You can increase the value of the timeout (by default 600 s) by setting the environment variable STARPU_TIMEOUT_ENV, e.g:
STARPU_TIMEOUT_ENV=2000 make check
You can also re-run configure with the option --enable-slow-machine which will lower default values for the testcases run by make check.
It if keeps failing, run 'make --keep-going check' to also check the execution in the other directories.
Cheers,
Nathalie
On 02/06/2012 06:08, Konstantin M. Khankin wrote:
Hello!
I was compiling StarPU from source code (oh, when RPMs will be available...):
./configure --enable-memory-status --enable-stats
        CPUs   enabled: yes
        CUDA   enabled: yes
        OpenCL enabled: yes
        Cell   enabled: no
        Compile-time limits
        (change these with --enable-maxcpus, --enable-maxcudadev,
        --enable-maxopencldev, --enable-maxbuffers)
        Maximum number of CPUs:           64
        Maximum number of CUDA devices:   4
        Maximum number of OpenCL devices: 8
        Maximum number of memory nodes:   13
        Maximum number of task buffers:   8
        GPU-GPU transfers: yes
        Allocation cache:  no
        Magma enabled: no
        BLAS library:  none
        hwloc:         yes
        FxT trace enabled: no
        StarPU-Top:        no
        StarPU Extensions:
               MPI enabled:   no
               MPI test suite: no
               FFT Support: yes
               GCC plug-in: no
               GCC plug-in test suite (requires GNU Guile): no
               SOCL enabled:  yes
make was done without any errors but with warning:
*** Warning: Linking the shared library libstarpufft-1.0.la against the non-libtool
*** objects  cudaf_kernels.o cuda_kernels.o is not portable!
make check returns this:
PASS: starpu_machine_display
PASS: main/deprecated_func
PASS: main/deprecated_buffer
PASS: main/restart
PASS: main/execute_on_a_specific_worker
PASS: main/insert_task
PASS: main/multithreaded
PASS: main/multithreaded_init
PASS: main/starpu_task_bundle
PASS: main/starpu_task_wait_for_all
PASS: main/static_restartable
PASS: main/static_restartable_using_initializer
PASS: main/static_restartable_tag
PASS: main/regenerate
PASS: main/wait_all_regenerable_tasks
PASS: main/subgraph_repeat
PASS: main/subgraph_repeat_regenerate
PASS: main/subgraph_repeat_regenerate_tag
PASS: main/empty_task
PASS: main/empty_task_sync_point
PASS: main/empty_task_sync_point_tasks
PASS: main/empty_task_chain
PASS: main/tag_wait_api
PASS: main/task_wait_api
PASS: main/declare_deps_in_callback
PASS: main/declare_deps_after_submission
PASS: main/declare_deps_after_submission_synchronous
PASS: main/get_current_task
PASS: main/starpu_init
PASS: main/starpu_worker_exists
PASS: datawizard/acquire_cb
PASS: datawizard/acquire_cb_insert
PASS: datawizard/acquire_release
PASS: datawizard/acquire_release2
PASS: datawizard/copy
PASS: datawizard/data_implicit_deps
PASS: datawizard/data_lookup
PASS: datawizard/scratch
PASS: datawizard/sync_and_notify_data
PASS: datawizard/sync_and_notify_data_implicit
PASS: datawizard/dsm_stress
PASS: datawizard/double_parameter
PASS: datawizard/write_only_tmp_buffer
PASS: datawizard/data_invalidation
PASS: datawizard/dining_philosophers
PASS: datawizard/manual_reduction
PASS: datawizard/readers_and_writers
PASS: datawizard/unpartition
PASS: datawizard/user_interaction_implicit  <=== there was a long time waiting after this line
FAIL: datawizard/reclaim
PASS: datawizard/sync_with_data_with_mem
PASS: datawizard/sync_with_data_with_mem_non_blocking
PASS: datawizard/sync_with_data_with_mem_non_blocking_implicit
PASS: datawizard/mpi_like
PASS: datawizard/mpi_like_async
PASS: datawizard/critical_section_with_void_interface
PASS: datawizard/increment_redux
PASS: datawizard/increment_redux_v2
PASS: datawizard/increment_redux_lazy
PASS: datawizard/handle_to_pointer
PASS: datawizard/lazy_allocation
PASS: datawizard/interfaces/copy_interfaces
PASS: datawizard/interfaces/block/block_interface
PASS: datawizard/interfaces/bcsr/bcsr_interface
PASS: datawizard/interfaces/csr/csr_interface
PASS: datawizard/interfaces/matrix/matrix_interface
PASS: datawizard/interfaces/multiformat/multiformat_interface
SKIP: datawizard/interfaces/multiformat/advanced/multiformat_cuda_opencl
SKIP: datawizard/interfaces/multiformat/advanced/multiformat_data_release
PASS: datawizard/interfaces/multiformat/advanced/multiformat_worker
PASS: datawizard/interfaces/multiformat/advanced/multiformat_handle_conversion
PASS: datawizard/interfaces/multiformat/advanced/same_handle
PASS: datawizard/interfaces/variable/variable_interface
PASS: datawizard/interfaces/vector/test_vector_interface
PASS: datawizard/interfaces/void/void_interface
PASS: datawizard/in_place_partition
PASS: datawizard/partition_lazy
PASS: datawizard/gpu_register
PASS: datawizard/wt_host
PASS: datawizard/wt_broadcast
SKIP: datawizard/readonly
PASS: errorcheck/starpu_init_noworker
PASS: errorcheck/invalid_blocking_calls
PASS: errorcheck/invalid_tasks
PASS: helper/cublas_init
PASS: helper/starpu_data_cpy
PASS: helper/pinned_memory
PASS: helper/execute_on_all
PASS: helper/starpu_create_sync_task
PASS: microbenchs/async_tasks_overhead
PASS: microbenchs/sync_tasks_overhead
PASS: microbenchs/tasks_overhead
PASS: microbenchs/prefetch_data_on_node
PASS: microbenchs/redundant_buffer
PASS: microbenchs/local_pingpong
PASS: overlap/overlap
PASS: parallel_tasks/explicit_combined_worker
PASS: parallel_tasks/parallel_kernels
PASS: parallel_tasks/parallel_kernels_spmd
PASS: perfmodels/regression_based
PASS: perfmodels/non_linear_regression_based
Test "datawizard/reclaim" was failed:
1 of 99 tests failed
(3 tests were not run)
See tests/test-suite.log
Please report to starpu-devel@lists.gforge.inria.fr
test-suite.log is in attachment
Please tell me what I've doing wrong
Thanks
With best regards
SUSU, Computer Department, P.G.
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
