Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] BCSR: the rowptr field.
Archives de la liste
Chronologique Discussions
  • To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] BCSR: the rowptr field.
  • Date: Fri, 08 Jun 2012 02:52:59 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hey !
I'm currently rewriting the BCSR test, and I have some trouble filling the rowptr field of the starpu_bcsr_interface structure. I want to use the following matrix :
0 1 0 0
2 3 0 0
4 5 8 9
6 7 10 11
with c = r = 2.
nzval is obviously :
[ 0, 1, 2, 3] (upper left block)
4, 5, 6, 7, (lower left block)
8, 9, 10, 11] (lower right block)
I think colind should be [0, 0, 2], since the first two blocks start at column 0, and the lower right block starts at column 2.
But I'm not sure of what should be put in the rowptr field. Does anyone master the BCSR format ?
Note that I could use fake values, since the test just makes sure that copying data from a device to another works. Still, I'd like to use meaningful values, so that the test can serve as an example of the use of the BCSR interface (I don't think we have any code using this interface in examples/).
Cyril.
Haut de le page
