Archives de la liste
- To: Alin Dobre <alin.dobre@movidius.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10
- Date: Wed, 06 Jun 2012 16:57:44 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
On 06/05/2012 05:03 PM, Alin Dobre wrote:
Hi,
I'm having some trouble building the library on Ubuntu 11.10 32bit, GCC
4.6.1.
I get undefined symbol errors for the OpenCL primitives provided by the
OpenCL library.
I have checked the library path and it is provided correctly.
Could you provide us with both your configure options and the error log ? Which OpenCL implementation do you use ?
I suspect the errors may be due to the fact that the -lOpenCL gets placed
before the file that is using the library function calls in the linker
command line.
I noticed that the -l directives should be placed after the file in order
for the linking to work properly.
It seems like this is what we do.
WBR,
Cyril Roelandt.
- [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10, Alin Dobre, 05/06/2012
- Re: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10, Cyril Roelandt, 06/06/2012
- Re: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10, Alin Dobre, 08/06/2012
- Re: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10, Samuel Thibault, 08/06/2012
- Re: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10, Alin Dobre, 11/06/2012
