Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] make distcheck fails
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] make distcheck fails
  • Date: Fri, 08 Jun 2012 13:01:17 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
All,
make distcheck fails on the current trunk with a configure started without specific options on a machine with no GPU device.
gcc-plugin/tests/opencl fails stating it can not find test.cl even though test.cl is available in the distrib file.
If the GCC-plugin team could please look at this problem ...
Cheers,
Nathalie
FAIL: opencl.c (exit: 1)
0 directives found in `../../../gcc-plugin/tests/opencl.c'
running `LC_ALL=C ./../../libtool --mode=link gcc -O0 -I ../../../gcc-plugin/tests -I ../../../gcc-plugin/tests/../../src -I ../../../gcc-plugin/tests/../../include -I ./../../include -I ./../.. -fplugin=./../src/.libs/starpu.so -fplugin-arg-starpu-include-dir=../../../include -fplugin-arg-starpu-opencl-include-dir=../../../gcc-plugin/tests -g -fdump-tree-gimple -Wall -o ./opencl "../../../gcc-plugin/tests/opencl.c" -L./../../src 2>&1'
error: 2 unmatched GCC diagnostics:
../../../gcc-plugin/tests/opencl.c:32:23: error: failed to access 'test.cl': No such file or directory
../../../gcc-plugin/tests/opencl.c:26:13: warning: 'my_task' used but never defined [enabled by default]
error: compilation failed (compiler exit code 256)
libtool: link: gcc -O0 -I ../../../gcc-plugin/tests -I ../../../gcc-plugin/tests/../../src -I ../../../gcc-plugin/tests/../../include -I ./../../include -I ./../.. -fplugin=./../src/.libs/starpu.so -fplugin-arg-starpu-include-dir=../../../include -fplugin-arg-starpu-opencl-include-dir=../../../gcc-plugin/tests -g -fdump-tree-gimple -Wall -o ./opencl ../../../gcc-plugin/tests/opencl.c -L./../../src
Haut de le page
