Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10
Archives de la liste
Chronologique Discussions
  • To: "'Cyril Roelandt'" <cyril.roelandt@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Building StarPU with OpenCL on Ubuntu 11.10
  • Date: Fri, 8 Jun 2012 11:41:12 +0300
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
The config.log is attached.
I used the following command line for configure:
./configure --enable-verbose --enable-debug --with-opencl-include-dir=/home/alin/SVN/StarPU/movidius/common --with-opencl-lib-dir=/home/alin/SVN/StarPU/movidius/linux32/lib --disable-socl --without-hwloc
Tho OpenCL  implementation is Movidius specific (Peppher project).
Thanks,
Alin
-----Original Message-----
From: Cyril Roelandt [mailto:cyril.roelandt@inria.fr]
Sent: Wednesday, June 06, 2012 5:58 PM
To: Alin Dobre
On 06/05/2012 05:03 PM, Alin Dobre wrote:
> Hi,
> I'm having some trouble building the library on Ubuntu 11.10 32bit,
> GCC 4.6.1.
> I get undefined symbol errors for the OpenCL primitives provided by
> the OpenCL library.
> I have checked the library path and it is provided correctly.
Could you provide us with both your configure options and the error log ? Which OpenCL implementation do you use ?
> I suspect the errors may be due to the fact that the -lOpenCL gets
> placed before the file that is using the library function calls in the
> linker command line.
> I noticed that the -l directives should be placed after the file in
> order for the linking to work properly.
It seems like this is what we do.
WBR,
Cyril Roelandt.
Attachment: config.log
Description: Binary data
Haut de le page
