Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] CUDA task and GCC plugin
- Date: Mon, 11 Jun 2012 15:17:02 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
I'm trying to play with mixing CUDA task and the GCC plugin, using the StarPU 1.0.1 tar.gz online.
First I wonder if I can declare a task with only a CUDA implementation and no CPU implementation ? Currently I always end up with a linker error.
I also wonder if there is a more verbose mode for StarPU ? Using --enable-debug and --enable-verbose juste give some initialization informations but I would also expect an output each time a task or a data transfer is scheduled.
I also have an issue related to implicit cpu implementations and -O3 gcc flag which seems to be broken. I'm testing a simple task call with a CPU and a CUDA implementation. Using -O3 the CPU task is always executed while without the -O3 flag the CUDA task is correctly executed. Is it a known issue ?
The issue doesn't occur with explicit tasks.
See attached to reproduce the issue (it took me a loooooong time to spot the origin of this issue...):
$ OPT_FLAG=-O2 ./compile-test.sh
Run with implicit CPU task, compiled and link at the same time
GPU !
Run with implicit CPU task, compiled and link separately
GPU !
Run with explicit CPU task, compiled and link at the same time
GPU !
Run with explicit CPU task, compiled and link separately
GPU !
$ OPT_FLAG=-O3 ./compile-test.sh
*CPU*
*CPU*
GPU !
GPU !
Best,
Mehdi
PS: I use a fedora core 16,
# StarPU configuration
$ ./config.status --config
'--disable-cpu' '--prefix=/home/amini/StarPU/starpu-install/' '--with-cuda-dir=/opt/cuda/' '--with-cuda-lib-dir=/usr/lib64/nvidia' 'LDFLAGS=-L/usr/lib64/nvidia/'
# GCC Version
$ gcc -v
Utilisation des specs internes.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/4.6.3/lto-wrapper
Target: x86_64-redhat-linux
Configuré avec: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --enable-languages=c,c++,objc,obj-c++,java,fortran,ada,go,lto --enable-plugin --enable-java-awt=gtk --disable-dssi --with-java-home=/usr/lib/jvm/java-1.5.0-gcj-1.5.0.0/jre --enable-libgcj-multifile --enable-java-maintainer-mode --with-ecj-jar=/usr/share/java/eclipse-ecj.jar --disable-libjava-multilib --with-ppl --with-cloog --with-tune=generic --with-arch_32=i686 --build=x86_64-redhat-linux
Modèle de thread: posix
gcc version 4.6.3 20120306 (Red Hat 4.6.3-2) (GCC)
#include <stdio.h> #include <unistd.h> #include <string.h> #include <math.h> #define NX 512 double A[NX]; double B[NX]; double E[NX]; static void launcher(const double A[NX], const double B[NX], double E[NX], int nx) __attribute__ ((task)); #ifndef IMPLICIT static void launcher_cpu(const double A[NX], const double B[NX], double E[NX], int nx) __attribute__ ((task_implementation ("cpu", launcher))); static void launcher_cpu(const double A[NX], const double B[NX], double E[NX], int nx) #else static void launcher(const double A[NX], const double B[NX], double E[NX], int nx) #endif { printf("CPU\n"); } extern void launcher_cuda(const double A[NX], const double B[NX], double E[NX], int nx) __attribute__ ((task_implementation ("cuda", launcher))); int main(int argc, char **argv) { int nx = NX; #pragma starpu initialize #pragma starpu register A #pragma starpu register B #pragma starpu register E launcher((double *)A, (double *)B, (double *)E, nx); #pragma starpu wait #pragma starpu unregister E return 0; }
kernel.cu
Description: application/cu-seeme
compile-test.sh
Description: application/shellscript
- [Starpu-devel] CUDA task and GCC plugin, Mehdi AMINI, 11/06/2012
- Re: [Starpu-devel] CUDA task and GCC plugin, Ludovic Courtès, 11/06/2012
- Re: [Starpu-devel] CUDA task and GCC plugin, Mehdi AMINI, 11/06/2012
- <Suite(s) possible(s)>
