Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] CUDA task and GCC plugin
Archives de la liste
Chronologique Discussions
  • To: mehdi.amini@silkan.com
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] CUDA task and GCC plugin
  • Date: Mon, 11 Jun 2012 16:52:02 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
Mehdi AMINI <mehdi.amini@silkan.com> skribis:
> First I wonder if I can declare a task with only a CUDA implementation
> and no CPU implementation ?
In theory, it should be possible.
> Currently I always end up with a linker error.
Oups, that’s a genuine bug (I’ve reproduced it.) I’ll let you know when
a fix is available.
> I also wonder if there is a more verbose mode for StarPU ? Using
> --enable-debug and --enable-verbose juste give some initialization
> informations but I would also expect an output each time a task or a
> data transfer is scheduled.
For such detailed information, you would probably need to generate
traces with FxT (info "(starpu) Off-line").
> I also have an issue related to implicit cpu implementations and -O3
> gcc flag which seems to be broken. I'm testing a simple task call with
> a CPU and a CUDA implementation. Using -O3 the CPU task is always
> executed while without the -O3 flag the CUDA task is correctly
> executed. Is it a known issue ?
I believe there’s nothing wrong here: the default scheduler (‘eager’)
makes non-deterministic scheduling decisions, and just happened to favor
CPU over CUDA for some reason.
Now, the CPU back-end can be disabled at run-time, forcing the scheduler
to use GPUs only:
$ STARPU_NCPUS=0 ./compile-test.sh
Run with implicit CPU task, compiled and link at the same time
GPU !
Run with implicit CPU task, compiled and link separately
GPU !
Run with explicit CPU task, compiled and link at the same time
GPU !
Run with explicit CPU task, compiled and link separately
GPU !
(Using ‘--disable-cpu’ should have the same effect; not sure why it
didn’t.)
The manual has more info about schedulers (info "(starpu) Task
scheduling policy").
Hope this helps,
Ludo’.
Haut de le page
