Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Subject: Re: [Starpu-devel] DAG with Tag dependences
- Date: Wed, 27 Jun 2012 08:43:44 +0000
- Accept-language: en-US
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
- Resent-date: Wed, 27 Jun 2012 07:46:16 -0300
- Resent-from: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Resent-message-id: <20120627104616.GF3298@type.lan>
- Resent-to: starpu-devel@lists.gforge.inria.fr
>From the new implemented graph, tags and tasks (not sure which is which)
>appear as nodes of the same type with cyclical dependences.
I basically have the graph I want with each node being a two node cycle graph
Task <-> Tag.
Is there no way to merge those two ? and have the DAG with task names in the
nodes (from task ?) and the dependences (from tags ?) ?
Also, I now have a lot of messages at the end of my program's execution.
And what looks like the same messages fro starpu_fxt_tool:
94 warnings of the form
profiling:/.../StarPU/src/.libs/libstarpu_1.0_la-footprint.gcda:Merge
mismatch for summaries
-- Lex
________________________________________
From: Samuel Thibault [samuel.thibault@ens-lyon.org]
Sent: Tuesday, June 26, 2012 12:12
To: Duchateau, Alexandre
Cc: starpu-devel@lists.gforge.inria.fr
Duchateau, Alexandre, le Tue 26 Jun 2012 17:10:22 +0200, a écrit :
> Attached is a small example (my larger cases have thousands of tasks)
> Am I missing something somewhere ?
It seems the relation between tags and tasks was not implemented. You
can try the latest svn, or the attached patch.
Samuel
output.pdf
Description: output.pdf
- [Starpu-devel] DAG with Tag dependences, Duchateau, Alexandre, 26/06/2012
- Re: [Starpu-devel] DAG with Tag dependences, Samuel Thibault, 26/06/2012
- Re: [Starpu-devel] DAG with Tag dependences, Duchateau, Alexandre, 27/06/2012
- Re: [Starpu-devel] DAG with Tag dependences, Samuel Thibault, 27/06/2012
