Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Bug autogen.sh
Archives de la liste
Chronologique Discussions
  • To: "starpu-devel " <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] Bug autogen.sh
  • Date: Fri, 13 Jul 2012 16:18:48 +0200 (CEST)
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
I have a problem with the autogen.sh.
I use the revision 6938.
Here is the output  of the autogen.sh:
nakov@mirage002:~/soft_src/starPU> ./autogen.sh
autoreconf: Entering directory `.'
autoreconf: configure.ac: not using Gettext
autoreconf: running: aclocal --force -I m4
autoreconf: configure.ac: tracing
autoreconf: running: libtoolize --copy --force
libtoolize: putting auxiliary files in AC_CONFIG_AUX_DIR, `build-aux'.
libtoolize: copying file `build-aux/ltmain.sh'
libtoolize: putting macros in `m4'.
libtoolize: copying file `m4/libtool.m4'
libtoolize: copying file `m4/ltoptions.m4'
libtoolize: copying file `m4/ltsugar.m4'
libtoolize: copying file `m4/ltversion.m4'
libtoolize: copying file `m4/lt~obsolete.m4'
libtoolize: Consider adding `AC_CONFIG_MACRO_DIR([m4])' to configure.ac and
libtoolize: rerunning libtoolize, to keep the correct libtool macros in-tree.
autoreconf: running: /usr/bin/autoconf --include=m4 --force
autoreconf: running: /usr/bin/autoheader --include=m4 --force
autoreconf: running: automake --add-missing --copy --force-missing
configure.ac:64: installing `build-aux/compile'
configure.ac:49: installing `build-aux/config.guess'
configure.ac:49: installing `build-aux/config.sub'
configure.ac:53: installing `build-aux/install-sh'
configure.ac:53: installing `build-aux/missing'
doc/Makefile.am:13: installing `build-aux/texinfo.tex'
examples/Makefile.am: installing `build-aux/depcomp'
configure.ac: installing `build-aux/ylwrap'
automake: starpu_calibrate_bus_OBJECTS should not be defined
tools/Makefile.am:23:   while processing program `starpu_calibrate_bus'
automake: starpu_fxt_stats_OBJECTS should not be defined
tools/Makefile.am:37:   while processing program `starpu_fxt_stats'
automake: starpu_fxt_tool_OBJECTS should not be defined
tools/Makefile.am:37:   while processing program `starpu_fxt_tool'
automake: starpu_machine_display_OBJECTS should not be defined
tools/Makefile.am:23:   while processing program `starpu_machine_display'
automake: starpu_perfmodel_display_OBJECTS should not be defined
tools/Makefile.am:23:   while processing program `starpu_perfmodel_display'
automake: starpu_perfmodel_plot_OBJECTS should not be defined
tools/Makefile.am:23:   while processing program `starpu_perfmodel_plot'
autoreconf: automake failed with exit status: 1
Stojce
Haut de le page
