Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Bug autogen.sh
Archives de la liste
Chronologique Discussions
  • To: Stojce Nakov <stojce.nakov@inria.fr>
  • Cc: starpu-devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] Bug autogen.sh
  • Date: Fri, 13 Jul 2012 17:36:44 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 07/13/2012 04:18 PM, Stojce Nakov wrote:
> Hello,
> I have a problem with the autogen.sh.
> I use the revision 6938.
> Here is the output of the autogen.sh:
You could try to disable the compilation of the tools:
--- a/trunk/Makefile.am
+++ b/trunk/Makefile.am
@@ -18,7 +18,7 @@ ACLOCAL_AMFLAGS=-I m4
CLEANFILES = *.gcno *.gcda *.linkinfo
SUBDIRS = src
-SUBDIRS += tools tests doc
+SUBDIRS += tests doc
if USE_MPI
SUBDIRS += mpi
This way, you will probably be able to compile StarPU and keep working
while we try to fix this issue.
Could you please give us the output of:
$ automake --version ?
Did you run ./autogen.sh on a clean tree, or on an older tree that you
recently updated ?
Cyril.
Haut de le page
