Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Roberto Ribeiro <rbrt.ribeiro@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] OpenMP StarPU
- Date: Tue, 25 Sep 2012 17:34:02 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
Roberto Ribeiro, le Tue 25 Sep 2012 17:23:17 +0200, a écrit :
> i'm looking for an aternative way to use OpenMP with StarPU without parallel
> tasks feature.
Out of curiosity, why do you want an alternative, exactly?
> My first approach is to init the system with a single CPU
> (conf.ncpus = 1) and inside the codelet func use #pragma omp parallel for.
> However, for some unknown reason the threads are instanced but they stall
> and
> the kernel remains sequential. Are you aware of anything that may cause
> this?
I guess this is because the only thread started by StarPU is bound to
only one core.
> One more thing, in your handbook you say:
> The solution is then to use only one combined worker at a time. This
> can be
> done by setting single_combined_worker to 1 in the starpu_conf
> structure,
> or setting the STARPU_SINGLE_COMBINED_WORKER environment variable to 1.
> StarPU will then run only one parallel task at a time.
> Does this mean that we can't have a GPU worker running concurrently and
> executing tasks with the same starpu_codelet?
No, I have just added “(but other CPU and GPU tasks are not affected
and can be run concurrently).”
> For instance, can we schedule a GEMM in a CPU+GPU system using any CPU
> BLAS implementation and cuBLAS?
Yes.
Samuel
- [Starpu-devel] OpenMP StarPU, Roberto Ribeiro, 25/09/2012
- Re: [Starpu-devel] OpenMP StarPU, Samuel Thibault, 25/09/2012
- Re: [Starpu-devel] OpenMP StarPU, Roberto Ribeiro, 25/09/2012
