Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Subject: Re: [Starpu-devel] OpenMP StarPU
- Date: Tue, 25 Sep 2012 16:50:31 +0100
- Authentication-results: iona.labri.fr (amavisd-new); dkim=pass header.i=@gmail.com
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
- Resent-date: Tue, 25 Sep 2012 17:52:50 +0200
- Resent-from: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Resent-message-id: <20120925155250.GO6096@type.oeaw.ads>
- Resent-to: starpu-devel@lists.gforge.inria.fr
Hi,
thanks for the quick answer.
The reason is basically because i cant make it work. Using single_combined_worker and starpu_combined_worker_get_size() will always return a single CPU. I've used your vector_scal.c example, compiled with the given command and the output is always: "running task with 1 CPUs".
How do we do it then? we may still specify a single codelet, use:
.type = STARPU_FORKJOIN,
.cpu_funcs = {CPU_func, NULL}
cuda_funcs= {CUDA_func, NULL};
and create subtasks with it?
RR
On Tue, Sep 25, 2012 at 4:34 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
Hello,
Roberto Ribeiro, le Tue 25 Sep 2012 17:23:17 +0200, a écrit :
> i'm looking for an aternative way to use OpenMP with StarPU without parallelOut of curiosity, why do you want an alternative, exactly?
> tasks feature.
I guess this is because the only thread started by StarPU is bound to
> My first approach is to init the system with a single CPU
> (conf.ncpus = 1) and inside the codelet func use #pragma omp parallel for.
> However, for some unknown reason the threads are instanced but they stall and
> the kernel remains sequential. Are you aware of anything that may cause this?
only one core.
No, I have just added “(but other CPU and GPU tasks are not affected
> One more thing, in your handbook you say:
> The solution is then to use only one combined worker at a time. This can be
> done by setting single_combined_worker to 1 in the starpu_conf structure,
> or setting the STARPU_SINGLE_COMBINED_WORKER environment variable to 1.
> StarPU will then run only one parallel task at a time.
> Does this mean that we can't have a GPU worker running concurrently and
> executing tasks with the same starpu_codelet?
and can be run concurrently).”
Yes.
> For instance, can we schedule a GEMM in a CPU+GPU system using any CPU
> BLAS implementation and cuBLAS?
Samuel
- [Starpu-devel] OpenMP StarPU, Roberto Ribeiro, 25/09/2012
- Re: [Starpu-devel] OpenMP StarPU, Samuel Thibault, 25/09/2012
- Re: [Starpu-devel] OpenMP StarPU, Roberto Ribeiro, 25/09/2012
