Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] Scheduler heft
- Date: Tue, 20 Nov 2012 09:25:53 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
All,
The internal function static int _heft_push_task(struct starpu_task *task, unsigned prio) does not use the parameter prio in its body. Is it an error? At some point, the task priority it set:
task->priority = 0;
Or is the parameter not needed and thus should be removed?
Cheers,
Nathalie
- [Starpu-devel] Scheduler heft, Nathalie Furmento, 20/11/2012
- Re: [Starpu-devel] Scheduler heft, Samuel Thibault, 20/11/2012
- Re: [Starpu-devel] Scheduler heft, Nathalie Furmento, 21/11/2012
- Re: [Starpu-devel] Scheduler heft, Samuel Thibault, 21/11/2012
