Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [PATCH 0/5] Merge heft and dmda.
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [PATCH 0/5] Merge heft and dmda.
  • Date: Fri, 07 Dec 2012 03:17:47 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 12/06/2012 10:56 AM, Nathalie Furmento wrote:
On 03/12/2012 20:46, Samuel Thibault wrote:
Cyril Roelandt, le Wed 28 Nov 2012 00:35:30 +0100, a écrit :
The following five patches merge heft and dmda. They work well on my
machine, I
just haven't run any benchmark. Samuel, the last time I hacked the
schedulers,
you ran a benchmark on Plafrim, could you run it again and tell me if
these
patches affect the performance ?
(and the patches look good to me)
Samuel
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
The serie of patches seems to have broken StarPU.
* Buildbot running with the default configuration on hannibal is
successfull, with revision #8179
http://dalton.bordeaux.inria.fr:8011/builders/hannibal-trunk-default/builds/486
On hannibal, it hangs with revision 8179.
I tried running mult/sgemm on attila, and got this output with both r.8233 and r.8192 (right before applying my patches):
BLAS : Program is Terminated. Because you tried to allocate too many memory regions.
Segmentation fault (core dumped)
* After the commits up to revision #8197,mult/sgemm timeouts
http://dalton.bordeaux.inria.fr:8011/builders/hannibal-trunk-default/builds/487
* With the following commits up to revision #8206, many examples fail:
http://dalton.bordeaux.inria.fr:8011/builders/hannibal-trunk-default/builds/488
All these failed tests use the eager scheduler, while most of my changes affected heft and dm*. Are you sure this issue comes from this patch series ? If the bug is reproducible, could you try and bisect this ?
Did you try to run a make check on hannibal before committing?
I think so, but well, I might have forgotten.
Cyril Roelandt.
Haut de le page
