Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [PATCH 0/5] Merge heft and dmda.
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: Cyril Roelandt <cyril.roelandt@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [PATCH 0/5] Merge heft and dmda.
  • Date: Fri, 7 Dec 2012 03:41:39 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Cyril Roelandt, le Fri 07 Dec 2012 03:30:45 +0100, a écrit :
> On 12/07/2012 03:29 AM, Samuel Thibault wrote:
> >Cyril Roelandt, le Fri 07 Dec 2012 03:25:33 +0100, a écrit :
> >>BLAS : Program is Terminated. Because you tried to allocate too many
> >>memory
> >>regions.
> >Oops, it seems it's using the libopenblas I had installed the other day
> >but then removed because of this bug. But I had only removed the -dev,
> >not the library. Apparently that's not enough. I have now dropped the
> >library too.
> A free BLAS library ? Nice.
Actually it's essentially gotoblas.
> Would this failure be easy to reproduce, in order to file a bug
> report?
Quite easy apparently: just run cholesky with a big enough number of
blocks & CPUs.
Samuel
Haut de le page
