Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Build error with icc (trunk)
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Keisuke Fukuda <fukuda@matsulab.is.titech.ac.jp>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Build error with icc (trunk)
  • Date: Tue, 11 Dec 2012 15:16:59 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Keisuke,
Could you please send us the config.log file and the output of the make command?
Regards,
Nathalie
On 11/12/2012 10:01, Keisuke Fukuda wrote: Dear StarPU developers,
On the trunk (rev 8284), there's a build problem on TSUBAME, which has icc as its default C compiler.
Whole the build log is attached, but the part looks like the following.
icc: command line warning #10006: ignoring unknown option '-dumpspecs'
icc: command line error: no files specified; for help type "icc -help"
make[3]: *** [ring_kernel.o] Error 1
make[3]: Leaving directory `/home0/usr1/11M37264/tmp/softwares/starpu-trunk/mpi/tests'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home0/usr1/11M37264/tmp/softwares/starpu-trunk/mpi/tests'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home0/usr1/11M37264/tmp/softwares/starpu-trunk/mpi'
make: *** [all-recursive] Error 1
1.0-branch and 1.0.4 tar ball have no problem.
Regards,
Keisuke
FUKUDA, Keisuke<fukuda@matsulab.is.titech.ac.jp>
Dept. of Math. & Comp. Sciences
Satoshi Matsuoka Lab.,
Tokyo Institute of Technology
福田圭祐 <fukuda@matsulab.is.titech.ac.jp>
東京工業大学 数理・計算科学専攻 松岡研究室
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Dr Nathalie Furmento                         CNRS R&D Engineer
Centre de Recherche INRIA Bordeaux Sud-Ouest http://www.labri.fr/~furmento/
200 avenue de la vieille Tour                Tel: +33 (0)5 24 57 41 20
33405 Talence cedex, FRANCE                  Fax: +33 (0)5 24 57 40 41
Haut de le page
