Archives de la liste
- To: Keisuke Fukuda <fukuda@matsulab.is.titech.ac.jp>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Build error with icc (trunk)
- Date: Tue, 11 Dec 2012 19:00:45 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
On 12/11/2012 10:01 AM, Keisuke Fukuda wrote:
Dear StarPU developers,
On the trunk (rev 8284), there's a build problem on TSUBAME, which has icc
as its default C compiler.
Whole the build log is attached, but the part looks like the following.
icc: command line warning #10006: ignoring unknown option '-dumpspecs'
icc: command line error: no files specified; for help type "icc -help"
The "-dumpspecs" option is GCC-specific, so ICC fails.
The command line that fails is:
/opt/cuda/4.1//bin/nvcc ring_kernel.cu -c -o ring_kernel.o -ccbin /usr/apps/openmpi/1.4.2/intel/bin/mpicc -I/opt/cuda/4.1/include/ -m64 --compiler-options -fno-strict-aliasing -I../../include/ -I../../include/ -I/home/usr1/11M37264/local/include -I/usr/include/libxml2
The "-ccbin" option specifies the compiler used by nvcc. Here, it is ".../intel/bin/mpicc", which is probably a wrapper around icc. I think that nvcc should be able to find GCC if it is installed - is gcc installed on your machine ?
I don't know if there is a way to remove the "-dumpspecs" option from the commande line.
1.0-branch and 1.0.4 tar ball have no problem.
That is quite surprising.
Regards,
Cyril Roelandt.
- [Starpu-devel] Build error with icc (trunk), Keisuke Fukuda, 11/12/2012
- Re: [Starpu-devel] Build error with icc (trunk), Nathalie Furmento, 11/12/2012
- Re: [Starpu-devel] Build error with icc (trunk), Cyril Roelandt, 11/12/2012
- Re: [Starpu-devel] Build error with icc (trunk), Keisuke Fukuda, 12/12/2012
