Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Peppher: Running StarPU + OpenCL on Cora
Archives de la liste
Chronologique Discussions
  • To: <starpu-devel@lists.gforge.inria.fr>
  • Cc: brendan.barry@movidius.com, Samuel Thibault <samuel.thibault@labri.fr>, david.nicholls@movidius.com
  • Subject: [Starpu-devel] Peppher: Running StarPU + OpenCL on Cora
  • Date: Tue, 18 Dec 2012 12:59:40 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi guys,
I’m having some problems running StarPU together with OpenCL on the Cora machine in Viena.
I am running on a node (node06) which has 3 OpenCL devices (StarPU finds them when benchmarking the performance initially).
I used the libstarpu-1.0.so library that was pre-installed on Cora at the location: /opt_new/global/peppher/install/lib
It seems that when running the application with STARPU_NCPUS=0, StarPU does not find any suitable worker to allocate to (starpu_task_submit returns error code: -ENODEV). I tried to find out what the error was and I used STARPU_GENERATE_TRACE=yes. The result was:
refocusing: ../include/starpu_util.h:211: starpu_get_env_number: Assertion `__extension__ ({ size_t __s1_len, __s2_len; (__builtin_constant_p (check) && __builtin_constant_p ("\0") && (__s1_len = strlen (check), __s2_len = strlen ("\0"), (!((size_t)(const void *)((check) + 1) - (size_t)(const void *)(check) == 1) || __s1_len >= 4) && (!((size_t)(const void *)(("\0") + 1) - (size_t)(const void *)("\0") == 1) || __s2_len >= 4)) ? __builtin_strcmp (check, "\0") : (__builtin_constant_p (check) && ((size_t)(const void *)((check) + 1) - (size_t)(const void *)(check) == 1) && (__s1_len = strlen (check), __s1_len < 4) ? (__builtin_constant_p ("\0") && ((size_t)(const void *)(("\0") + 1) - (size_t)(const void *)("\0") == 1) ? __builtin_strcmp (check, "\0") : (__extension__ ({ __const unsigned char *__s2 = (__const unsigned char *) (__const char *) ("\0"); register int __result = (((__const unsigned char *) (__const char *) (check))[0] - __s2[0]); if (__s1_len > 0 && __result == 0) { __result = (((__const unsigned char *) (__const char *) (check))[1] - __s2[1]); if (__s1_len > 1 && __result == 0) { __result = (((__const unsigned char *) (__const char *) (check))[2] - __s2[2]); if (__s1_len > 2 && __result == 0) __result = (((__const unsigned char *) (__const char *) (check))[3] - __s2[3]); } } __result; }))) : (__builtin_constant_p ("\0") && ((size_t)(const void *)(("\0") + 1) - (size_t)(const void *)("\0") == 1) && (__s2_len = strlen ("\0"), __s2_len < 4) ? (__builtin_constant_p (check) && ((size_t)(const void *)((check) + 1) - (size_t)(const void *)(check) == 1) ? __builtin_strcmp (check, "\0") : (__extension__ ({ __const unsigned char *__s1 = (__const unsigned char *) (__const char *) (check); register int __result = __s1[0] - ((__const unsigned char *) (__const char *) ("\0"))[0]; if (__s2_len > 0 && __result == 0) { __result = (__s1[1] - ((__const unsigned char *) (__const char *) ("\0"))[1]); if (__s2_len > 1 && __result == 0) { __result = (__s1[2] - ((__const unsigned char *) (__const char *) ("\0"))[2]); if (__s2_len > 2 && __result == 0) __result = (__s1[3] - ((__const unsigned char *) (__const char *) ("\0"))[3]); } } __result; }))) : __builtin_strcmp (check, "\0")))); }) == 0' failed.
Aborted
When running StarPU with CUDA it works fine, so I assume that the GPU driver is accessed correctly.
The StarPU + OpenCL application ran perfectly on other machines, so it might be some setup issue.
Could you give me some feedback on what could be the issue?
Regards,
Alin
bringing mobile to life!
Alin Dobre
Movidius SRL
Str. Paris nr. 2A, P01
Timisoara 300003
Timis, Romania
Email: alin.dobre@movidius.com
Web: www.movidius.com
Watch us on YouTube
Follow us on Twitter or Facebook
Haut de le page
