Archives de la liste
Re: [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER
Chronologique Discussions
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER
- Date: Wed, 12 Dec 2012 14:41:06 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Nathalie Furmento, le Wed 12 Dec 2012 13:55:34 +0100, a écrit :
> I implemented your proposal. However, as it is checking the availability of
> the gordon implementation, it will very likely always return 0.
It should check for what is actually available to StarPU, i.e. if there
are only CPUs, only check for a CPU implementation.
Samuel
- [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER, Nathalie Furmento, 12/12/2012
- Re: [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER, Andra Hugo, 12/12/2012
- Re: [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER, Nathalie Furmento, 12/12/2012
- Re: [Starpu-devel] internal function _starpu_can_use_nth_implementation called with STARPU_ANY_WORKER, Samuel Thibault, 12/12/2012
