Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Assert fail with 8659
- Date: Fri, 15 Feb 2013 10:42:32 +0100 (CET)
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi,
It works for me now! I did not clean properly magma!
Andra
Andra
De: "Sylvain HENRY" <sylvain.henry@inria.fr>
À: starpu-devel@lists.gforge.inria.fr
Envoyé: Vendredi 15 Février 2013 10:01:45
Objet: Re: [Starpu-devel] Assert fail with 8659
Hi,
Andra has the same bug so the problem is more likely in StarPU.
Cheers
Sylvain
Le 15/02/2013 09:54, Xavier Lacoste a écrit :
BED93F1F-D7FD-4E00-AE80-F7968BD404A9@inria.fr">Hello, I still have the assert() problem with my code on mirage001. I'll check in my code that I really give correct inputs to StarPU, the error can come from one of my changes...
I runned make check : 1 of 113 tests failed (2 tests were not run) If I understood well this is the one which failed : [starpu][starpu_init] Warning: StarPU was configured with --with-fxt, which slows down a bit [starpu][initialize_eager_center_policy] Warning: you are running the default eager scheduler, which is not very smart. Make sure to read the StarPU documentation about adding perfo rmance models in order to be able to use the dmda scheduler instead. [starpu][starpu_init] Warning: StarPU was configured with --with-fxt, which slows down a bit Warning: change output file name to /tmp/prof_file_lacoste_0, but some events have been saved in file /tmp/prof_file_lacoste_0 [starpu][initialize_eager_center_policy] Warning: you are running the default eager scheduler, which is not very smart. Make sure to read the StarPU documentation about adding perfo rmance models in order to be able to use the dmda scheduler instead. [starpu][starpu_init] Warning: StarPU was configured with --with-fxt, which slows down a bit Warning: change output file name to /tmp/prof_file_lacoste_0, but some events have been saved in file /tmp/prof_file_lacoste_0 [starpu][initialize_eager_center_policy] Warning: you are running the default eager scheduler, which is not very smart. Make sure to read the StarPU documentation about adding perfo rmance models in order to be able to use the dmda scheduler instead. All CUDA-capable devices are busy or unavailable oops in init_context (drivers/cuda/driver_cuda.c:240)... 29: unload of CUDA runtime failed oops in init_context (drivers/cuda/driver_cuda.c:240)... 29: unload of CUDA runtime failed [starpu][abort] drivers/cuda/driver_cuda.c:582 starpu_cuda_report_error [starpu][abort] drivers/cuda/driver_cuda.c:582 starpu_cuda_report_error [error] `./main/restart' killed with signal 6; test marked as failed while looking for core file of ./main/restart: core: No such file or directory #Execution_time_in_seconds 5.340971 ./main/restart FAIL: main/restart XL. Le 14 févr. 2013 à 20:44, Nathalie Furmento a écrit :I was not able to reproduce it running make check on StarPU on my laptop. If the problem is still there Xavier, please send us the output of config.log, and the configuration of your machine (namely which machine you are using on plafrim). Cheers, Nathalie On Feb 14, 20:29, Samuel Thibault wrote:Xavier Lacoste, le Thu 14 Feb 2013 18:07:31 +0100, a écrit :The compilation passed with this configure line : ./configure --prefix=/home/lacoste/starpu-trunk-cuda --with-fxt --enable-maxcpus=160 --enable-max-sched-ctxs=30 CC=gcc CXX=g++ F77=gfortran --disable-opencl --with-cuda-dir=/opt/cluster/gpu/cuda/latest --with-cuda-lib-dir=/opt/cluster/gpu/cuda/latest/lib64/And is the assertion failure gone away? Samuel
_______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- Re: [Starpu-devel] hang with 8659, (suite)
- Re: [Starpu-devel] hang with 8659, Xavier Lacoste, 19/02/2013
- Re: [Starpu-devel] hang with 8659, Samuel Thibault, 19/02/2013
- Re: [Starpu-devel] hang with 8659, Xavier Lacoste, 20/02/2013
- Re: [Starpu-devel] hang with 8659, Samuel Thibault, 20/02/2013
- Re: [Starpu-devel] hang with 8659, Samuel Thibault, 22/02/2013
- Re: [Starpu-devel] hang with 8659, Xavier Lacoste, 23/02/2013
- Re: [Starpu-devel] Assert fail with 8659, Andra Hugo, 15/02/2013
