Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] StarPU CUDA out of memory
Archives de la liste
Chronologique Discussions
  • To: <starpu-devel@lists.gforge.inria.fr>
  • Subject: [Starpu-devel] StarPU CUDA out of memory
  • Date: Mon, 18 Feb 2013 09:43:50 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
I am getting "out of memory" error with CUDA fermi GPU when using StarPU.
I am executing a "call" 15 times in a loop and I do it in the following way:
for(i=1...15)
starpu_data_register(...) calls
function_call(...)
starpu-data_unregister() calls
When executing call directly with CUDA (i.e. without starpu) the call works fine and the memory consumption is at max 1085MB for my problem size while the available GPU memory is around 2687MB (checked using nvidia-smi).
With StarPU it seems that CUDA memory is not actually freed on "data_unregister" and that creates problem as memory consumption reaches 2109MB already on 2nd execution and after that all remaining 13 executions fail with "out of memory" error.
What do you think?
regards,
Usman.
Haut de le page
