Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] hang with 8659
- Date: Fri, 15 Feb 2013 11:28:57 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Here is my code,
I have lost the working revision number I'll try to find it.
I don't know how to call this as I cannot call underline prefixed function
outside from starpu, but if it doesn't really matter i can do without it.
XL.
starpu_pastix_sched_policy.c
Description: Binary data
Le 15 févr. 2013 à 11:11, Samuel Thibault a écrit :
> Xavier Lacoste, le Fri 15 Feb 2013 11:02:35 +0100, a écrit :
>> I see that
>> _starpu_push_task_end(task);
>> was added in commit 8462
>> Do I need an API available equivalent in my push_task() code?
> Ideally yes, but it probably doesn't have to do with the bug at stake,
> as it's only about some accounting, and about bundles. Put it right
> after you have pushed the task to some list.
> Since when are you getting this hang, exactly?
> It would probably be useful that you show us your scheduler code.
> Samuel
- Re: [Starpu-devel] Assert fail with 8659, (suite)
- Re: [Starpu-devel] Assert fail with 8659, Xavier Lacoste, 15/02/2013
- Re: [Starpu-devel] Assert fail with 8659, Sylvain HENRY, 15/02/2013
- Re: [Starpu-devel] Assert fail with 8659, Nathalie Furmento, 15/02/2013
- Re: [Starpu-devel] Assert fail with 8659, Andra Hugo, 15/02/2013
- Re: [Starpu-devel] hang with 8659, Samuel Thibault, 15/02/2013
- Re: [Starpu-devel] hang with 8659, Xavier Lacoste, 15/02/2013
- Re: [Starpu-devel] hang with 8659, Xavier Lacoste, 19/02/2013
- Re: [Starpu-devel] hang with 8659, Samuel Thibault, 19/02/2013
- Re: [Starpu-devel] hang with 8659, Xavier Lacoste, 20/02/2013
- Re: [Starpu-devel] hang with 8659, Samuel Thibault, 20/02/2013
- Re: [Starpu-devel] hang with 8659, Samuel Thibault, 22/02/2013
