Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] hang with 8659
Veuillez patienter...
starpu-devel@inria.fr
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] hang with 8659
  • Date: Tue, 19 Feb 2013 11:05:13 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
More info about my scheduler deadlock.
When I trace _starpu_increment_nready / _starpu_decrement_nready calls I see
that the cuda worker increment the counter but never decrement it, whereas
CPU workers always do (++, --) couples.
On that small case, the GPU stole 3 tasks from CPU and did 6 increment on
nready and no decrement.
Any Idea of what I missed ?
XL.
Le 15 févr. 2013 à 15:26, Xavier Lacoste a écrit :
> My deadlock is coming from the fact that the CUDA worker starts with no
> task (I think, i'm not exactly sure).
> I don't explain why this is an issue with my modified work stealing policy
> but that is my conclusion so far (Only CPUs => OK, 1 CUDA => deadlock).
> I didn't get any deadlock with my scheduler before because I wasn't using
> GPUs, nothing linked to the StarPU revision sorry for my bad report...
> XL.
> Le 15 févr. 2013 à 11:28, Xavier Lacoste a écrit :
>> Here is my code,
>> I have lost the working revision number I'll try to find it.
>> I don't know how to call this as I cannot call underline prefixed function
>> outside from starpu, but if it doesn't really matter i can do without it.
>> XL.
>> <starpu_pastix_sched_policy.c>
>> Le 15 févr. 2013 à 11:11, Samuel Thibault a écrit :
>>> Xavier Lacoste, le Fri 15 Feb 2013 11:02:35 +0100, a écrit :
>>>> I see that
>>>> _starpu_push_task_end(task);
>>>> was added in commit 8462
>>>> Do I need an API available equivalent in my push_task() code?
>>> Ideally yes, but it probably doesn't have to do with the bug at stake,
>>> as it's only about some accounting, and about bundles. Put it right
>>> after you have pushed the task to some list.
>>> Since when are you getting this hang, exactly?
>>> It would probably be useful that you show us your scheduler code.
>>> Samuel
>> _______________________________________________
>> Starpu-devel mailing list
>> Starpu-devel@lists.gforge.inria.fr
>> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
