Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU CUDA out of memory
- Date: Mon, 25 Feb 2013 10:03:56 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Thanks for the fix.
Just found a minor issue in workers.c: for (impl = 0; impl < STARPU_MAXIMPLEMENTATIONS; impl++) { ... case STARPU_CPU_WORKER: if (task->cl->cpu_funcs[ i ] != NULL) ... case STARPU_CUDA_WORKER: if (task->cl->cuda_funcs[ i ] != NULL) ... case STARPU_OPENCL_WORKER: if (task->cl->opencl_funcs[ i ] != NULL) ... ... } Should be "impl" instead of "i" as follow (?) for (impl = 0; impl < STARPU_MAXIMPLEMENTATIONS; impl++) { ... case STARPU_CPU_WORKER: if (task->cl->cpu_funcs[ impl ] != NULL) ... case STARPU_CUDA_WORKER: if (task->cl->cuda_funcs[ impl ] != NULL) ... case STARPU_OPENCL_WORKER: if (task->cl->opencl_funcs[ impl ] != NULL) ... ... } regards, Usman.On 02/22/2013 12:15 PM, Samuel Thibault wrote: Hello, Samuel Thibault, le Mon 18 Feb 2013 16:36:02 +0100, a écrit : Usman Dastgeer, le Mon 18 Feb 2013 10:22:07 +0100, a écrit :I am using both vector and matrix interface. Here is a simple program to reproduce the error.It's a deep problem in CUDA. We didn't know that even just starting a kernel could have to allocate memory and thus fail... So we're currently having a look at limiting the amount of memory that StarPU uses. This is now available. For now we don't limit automatically (since AFAIK CUDA doesn't provide a way to know how much memory is left), you can however set it by hand: export STARPU_LIMIT_CUDA_MEM=1900 to limit to 1.9GiB over 2GiB for instance, thus leaving 0.1GiB for CUDA-internal allocations. Samuel |
- [Starpu-devel] StarPU CUDA out of memory, Usman Dastgeer, 18/02/2013
- Re: [Starpu-devel] StarPU CUDA out of memory, Samuel Thibault, 18/02/2013
- Re: [Starpu-devel] StarPU CUDA out of memory, Usman Dastgeer, 18/02/2013
- Re: [Starpu-devel] StarPU CUDA out of memory, Samuel Thibault, 22/02/2013
- Re: [Starpu-devel] StarPU CUDA out of memory, Usman Dastgeer, 25/02/2013
- Re: [Starpu-devel] StarPU CUDA out of memory, Samuel Thibault, 25/02/2013
