Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: arun kumar <kumar0746@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] error in installing starpu
- Date: Mon, 4 Mar 2013 11:31:29 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
arun kumar, le Mon 04 Mar 2013 10:55:36 +0100, a écrit :
> after installing starpu in ubuntu 11.10 when i compile using the command
> given
> in http://runtime.bordeaux.inria.fr/StarPU/starpu.html i get the following
> error.
> cc1: error: cannot load plugin -L/usr/local/lib
> -L/usr/local/lib: cannot open shared object file: No such file or directory
> how to rectify this.
Could you provide us with the content of the config.log file, as well as
the output of
make V=1
In the meanwhile, you can probably fix the issue by passing
--disable-gcc-extensions
to ./configure, but it's just a workaround, and we need to fix the bug,
thus information about what went wrong on your system.
Samuel
- [Starpu-devel] error in installing starpu, arun kumar, 04/03/2013
- Re: [Starpu-devel] error in installing starpu, Samuel Thibault, 04/03/2013
- Re: [Starpu-devel] error in installing starpu, arun kumar, 05/03/2013
- Re: [Starpu-devel] error in installing starpu, Nathalie Furmento, 11/03/2013
