Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] error in installing starpu
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: arun kumar <kumar0746@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] error in installing starpu
  • Date: Mon, 11 Mar 2013 16:56:47 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Could you please also send the output of
make V=1
And which version of StarPU did you use?
Thanks,
Nathalie
On 05/03/2013 04:27, arun kumar wrote: HI,
I passed --disable-gcc-extensions command to config file still i get the same error.
On Tue, Mar 5, 2013 at 8:40 AM, arun kumar <kumar0746@gmail.com> wrote:
Hi,
I have attached config.log file. thank you.
Regards,
Arun Kumar S
On Mon, Mar 4, 2013 at 4:01 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
Hello,
arun kumar, le Mon 04 Mar 2013 10:55:36 +0100, a écrit :
>  after installing starpu in ubuntu 11.10 when i compile using the command given
> in http://runtime.bordeaux.inria.fr/StarPU/starpu.html i get the following
> error.
>  cc1: error: cannot load plugin -L/usr/local/lib
> -L/usr/local/lib: cannot open shared object file: No such file or directory
> how to rectify this.
Could you provide us with the content of the config.log file, as well as
the output of
make V=1
In the meanwhile, you can probably fix the issue by passing
to ./configure, but it's just a workaround, and we need to fix the bug,
thus information about what went wrong on your system.
Samuel
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
Haut de le page
