Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] starpu_malloc() when StarPU is not initialized yet (or has been shut down)
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] starpu_malloc() when StarPU is not initialized yet (or has been shut down)
  • Date: Thu, 14 Mar 2013 11:25:17 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
I have an application that can run in several contexts.
The application can be linked to StarPU but run without StarPU, and can partially run using StarPU, and enter the same C function called by a StarPU task, but before starpu_init() and/or after starpu_shutdown().
I would like to use starpu_malloc() instead of malloc(). However, reading the code in src/datawizard/malloc.c, it is not clear to me whether it is safe to call starpu_malloc() outside of starpu_init()/shutdown(), and the overhead of starpu_malloc() compared to malloc() is not clear either.
So,
  • Is it OK to call starpu_malloc() all the time ? (as long as the application is linked to StarPU, of course)
  • If not, should I maintain a variable is_starpu_initialized ?
  • Is the overhead of starpu_malloc() low enough to replace malloc(), even with one or more CUDA worker(s) ?
Thank you,
Benoit
Haut de le page
