Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] Tags and Sequential Consistency
- Date: Fri, 15 Mar 2013 01:14:11 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hi,
there is my situation :
- I submit a task B, depending by tag on the task A, which reads a data H
- I submit a task A (with a callback, so the order can be different) which writes H.
In Starpu, if I do not use starpu_data_set_sequential_consistency_flag to disable the consistency on the handle, there is a deadlock if the task B is submitted first.
Could not Starpu detect this pattern and do not add the automatic dependency ? Or maybe is it possible to warn in the debug mode ?
This problem is that, in my case, I have other tasks for which I want to benefit from the automatic dependency. For example a task C, submitted after the task B and writting H. So, I have handled it in a different way, but it is a suggestion.
Thank you.
Cyril.
- [Starpu-devel] Tags and Sequential Consistency, Cyril Bordage, 15/03/2013
- Re: [Starpu-devel] Tags and Sequential Consistency, Samuel Thibault, 15/03/2013
- Re: [Starpu-devel] Tags and Sequential Consistency, Samuel Thibault, 22/03/2013
