Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Tags and Sequential Consistency
Archives de la liste
Chronologique Discussions
  • From: Samuel Thibault <samuel.thibault@ens-lyon.org>
  • To: Cyril Bordage <cyril.bordage@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Tags and Sequential Consistency
  • Date: Fri, 15 Mar 2013 01:25:22 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Cyril Bordage, le Fri 15 Mar 2013 01:14:43 +0100, a écrit :
> there is my situation :
>   - I submit a task B, depending by tag on the task A, which reads a data H
>   - I submit a task A (with a callback, so the order can be different) which
> writes H.
Oh!
That can explain things we were wondering today indeed :)
> Could not Starpu detect this pattern and do not add the automatic
> dependency ?
I'd rather avoid this: that'd introduce obscure behaviors.
> Or maybe is it possible to warn in the debug mode ?
When StarPU does not progress any more, it could indeed have some code
to look for circular dependencies.
> This problem is that, in my case, I have other tasks for which I want to
> benefit from the automatic dependency. For example a task C, submitted after
> the task B and writting H. So, I have handled it in a different way, but it
> is
> a suggestion.
It would be easy to add a "sequential_consistency" field to the task
structure, defaulting to 1, and sequential consistency would be enabled
only if both the data and the task have enabled it.
Samuel
Haut de le page
