Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU gcc plugin not building
Archives de la liste
Chronologique Discussions
  • To: Ludovic Courtès <ludovic.courtes@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU gcc plugin not building
  • Date: Tue, 23 Apr 2013 14:53:41 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
ok, i was actually using gcc, but i named the file "main.cpp" instead of "main.c" which was pushing it to g++ automatically. With gcc it seems to work
Now, this might raise a problem for my project. Will i have any trouble if i compile the kernels separately as C code with gcc, but invoke them within C++ code?
Also, are these issues just specific to the plugin version? if required, i might just have use the API version, as long as it is more stable
And by the way, should i expect the same performance between both versions (Plugin and API)?
Greetings
Miguel Palhas
On Tue, Apr 23, 2013 at 2:40 PM, Ludovic Courtès <ludovic.courtes@inria.fr> wrote:
Ah, I can reproduce it too with g++, specifically:
  hello.c:1:50: internal compiler error: in xref_tag, at cp/decl.c:11202
I see what the problem is, but for now, you’ll have to use ‘gcc’, not ‘g++’.
Can you confirm that compiling the example with ‘gcc’ instead of ‘g++’ works?
TIA,
Ludo’.
Cumprimentos
Miguel Palhas
Haut de le page
