Archives de la liste
- To: Miguel Palhas <mpalhas@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU gcc plugin not building
- Date: Tue, 23 Apr 2013 16:21:30 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Miguel Palhas <mpalhas@gmail.com> skribis:
> Now, this might raise a problem for my project. Will i have any trouble if
> i compile the kernels separately as C code with gcc, but invoke them within
> C++ code?
No. Just make sure to declare the C functions within an ‘extern "C"’ block.
> Also, are these issues just specific to the plugin version? if required, i
> might just have use the API version, as long as it is more stable
Yes, these issues are caused by the GCC plug-in.
> And by the way, should i expect the same performance between both versions
> (Plugin and API)?
Yes. However, the C extensions supported by the plug-in are less
expressive than the C API, and you may find that you need some of the
features available in the API and not as C extensions, such as data
partitioning.
Ludo’.
- [Starpu-devel] StarPU gcc plugin not building, Miguel Palhas, 17/04/2013
- Re: [Starpu-devel] StarPU gcc plugin not building, Nathalie Furmento, 17/04/2013
- Re: [Starpu-devel] StarPU gcc plugin not building, Samuel Thibault, 18/04/2013
- Re: [Starpu-devel] StarPU gcc plugin not building, Miguel Palhas, 19/04/2013
- Re: [Starpu-devel] StarPU gcc plugin not building, Nathalie Furmento, 19/04/2013
- Re: [Starpu-devel] StarPU gcc plugin not building, Miguel Palhas, 23/04/2013
- Re: [Starpu-devel] StarPU gcc plugin not building, Ludovic Courtès, 23/04/2013
