Archives de la liste
- From: Samuel Thibault <samuel.thibault@ens-lyon.org>
- To: Miguel Palhas <mpalhas@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Problem running CUDA task
- Date: Wed, 5 Jun 2013 16:25:14 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Miguel Palhas, le Wed 05 Jun 2013 15:16:16 +0100, a écrit :
> This is an old question so i'll have to check if i'm thinking this right,
> but i
> believe the problem was due to the machine i use having 2 GPU's, one of
> which
> only supports an older computational capability. half the times, the kernel
> was
> being sent to the secondary GPU which didn't support the compiled kernel
> correctly, and probably issued an error.
Oh, indeed.
> setting the STARPU_NCUDA=1 environment variable solved the problem
Or better, you can use the .can_execute hook to tell StarPU more
precisely which device can execute which kernel.
Samuel
- Re: [Starpu-devel] Problem running CUDA task, Samuel Thibault, 05/06/2013
- Re: [Starpu-devel] Problem running CUDA task, Miguel Palhas, 05/06/2013
