Archives de la liste
- To: Samuel Thibault <samuel.thibault@ens-lyon.org>, Miguel Palhas <mpalhas@gmail.com>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Problem running CUDA task
- Date: Wed, 5 Jun 2013 15:33:06 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
yes, i noticed that feature when i was fixing this error.
But since my approach worked, and i don't want to use that GPU for any kind of processing anyway, it didn't seem worth the extra trouble
On Wed, Jun 5, 2013 at 3:25 PM, Samuel Thibault <samuel.thibault@ens-lyon.org> wrote:
Miguel Palhas, le Wed 05 Jun 2013 15:16:16 +0100, a écrit :
> This is an old question so i'll have to check if i'm thinking this right, but iOh, indeed.
> believe the problem was due to the machine i use having 2 GPU's, one of which
> only supports an older computational capability. half the times, the kernel was
> being sent to the secondary GPU which didn't support the compiled kernel
> correctly, and probably issued an error.
Or better, you can use the .can_execute hook to tell StarPU more
> setting the STARPU_NCUDA=1 environment variable solved the problem
precisely which device can execute which kernel.
Samuel
Cumprimentos
Miguel Palhas
- Re: [Starpu-devel] Problem running CUDA task, Samuel Thibault, 05/06/2013
- Re: [Starpu-devel] Problem running CUDA task, Miguel Palhas, 05/06/2013
