Archives de la liste
- From: Sébastien Frémal <sebastien.fremal@gmail.com>
- To: starpu-devel <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] How does StarPU get the OpenCL device ID ?
- Date: Fri, 7 Jun 2013 17:20:22 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
I've executed the hello_world example of starpu with a library doing RPC for opencl calls. When I execute the example on the same machine than the server, all work fine :
Executing : clCreateContext
Adresse du context : 0x7f332c297e80
Executing : clCreateCommandQueue
Adresse de la queue : 139857766440128
Executing : clGetDeviceInfo
Adresse de la queue : 139857766471632
Hello world (params = {1, 2.000000} )
Callback function got argument 0x42
Executing : clReleaseContext
ReleaseContext is a success
Executing : clReleaseCom mandQueue
ReleaseCommandQueue is a success
Executing : clReleaseCommandQueue
When I execute the example in a virtual machine, there is a problem with the device ID :
oops in _starpu_opencl_init_context (drivers/opencl/driver_opencl.c:140) ... <Invalid device> (-33)
lt-hello_world: ../include/starpu_opencl.h:41: starpu_opencl_report_error: Assertion `0' failed.
The device ID found by StarPU is 0. As the function clGetDeviceIDs is not called, I guess StarPU uses another way to get the device ID (maybe reading the number of the pci port ?), which doesn't work as the virtual environment has no information about the GPU.
Is it possible to get informations on that topic and where that specific call to clCreateContext is executed please ?
Best regards,
Sebastien Fremal
- [Starpu-devel] How does StarPU get the OpenCL device ID ?, Sébastien Frémal, 07/06/2013
- Re: [Starpu-devel] How does StarPU get the OpenCL device ID ?, Samuel Thibault, 09/06/2013
