Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] StarPU and MKL 11 (Intel Composer XE 2013)
- Date: Mon, 17 Jun 2013 17:54:02 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Hello,
I recently talked off-list with some of you about some issues with MKL 11 and StarPU.
I'm using StarPU (1.1rc1 and 1.0.5) on Linux with MKL, using 1 thread for MKL and doing all the parallelism using StarPU (no multithreaded tasks), setting MKL_NUM_THREADS to 1.
The threaded MKL library is used, with iomp5.
Using this configuration, StarPU used only 1 core, no matter the value of STARPU_NCPU. Samuel mentionned that it looked like a thread pinning issue with MKL.
I think I've found the solution: setting KMP_AFFINITY to disabled (http://software.intel.com/sites/products/documentation/studio/composer/en-us/2011Update/compiler_c/optaps/common/optaps_openmp_thread_affinity.htm). I wanted to share this workaround here.
Benoit Lize
- [Starpu-devel] StarPU and MKL 11 (Intel Composer XE 2013), Benoît Lizé, 17/06/2013
- Re: [Starpu-devel] StarPU and MKL 11 (Intel Composer XE 2013), Nathalie Furmento, 18/06/2013
