Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Benoît Lizé <benoit.lize@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU and MKL 11 (Intel Composer XE 2013)
- Date: Tue, 18 Jun 2013 09:49:20 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel>
Thanks Benoit for your feedback.
I added your explanation in the documentation.
Cheers,
Nathalie
On Jun 17, 17:54, Benoît Lizé wrote:
> Hello,
> I recently talked off-list with some of you about some issues with MKL 11
> and StarPU.
> I'm using StarPU (1.1rc1 and 1.0.5) on Linux with MKL, using 1 thread for
> MKL and doing all the parallelism using StarPU (no multithreaded tasks),
> setting MKL_NUM_THREADS to 1.
> The threaded MKL library is used, with iomp5.
> Using this configuration, StarPU used only 1 core, no matter the value of
> STARPU_NCPU. Samuel mentionned that it looked like a thread pinning issue
> with MKL.
> I think I've found the solution: setting KMP_AFFINITY to disabled (
> http://software.intel
> .com/sites/products/documentation/studio/composer/en-us/2011Update/compiler_c/
> optaps/common/optaps_openmp_thread_affinity.htm). I wanted to share this
> workaround here.
> Benoit Lize
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> http://lists.gforge.inria.fr/cgi-bin/mailman/listinfo/starpu-devel
- [Starpu-devel] StarPU and MKL 11 (Intel Composer XE 2013), Benoît Lizé, 17/06/2013
- Re: [Starpu-devel] StarPU and MKL 11 (Intel Composer XE 2013), Nathalie Furmento, 18/06/2013
